Question about Briggs & Stratton Garden
Does not Charge Battery
Briggs & Stratton engine model 287707 engine type 1272-E1
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
If the motor is doing less voltage running then when its shut down then you need a new voltage or charging ring under your fly wheel,pretty easy job pull off fly wheel should be 3 to4 bolts that holds the copper charging ring on,you want to make sure you get the model no.off the engine not the frame of mower get new one it plugs in you will see where it plugs in and definitely check your magnets inside of fly wheel blow the fly wheel out ood with air and inspect the magnets,if everything looks good bolt new ring in and do the reverse effect putting it back together and should be good to go,may want to charge battery while your doing this and before you start this project take off your battery wires good luck!!
Posted on Nov 12, 2014
    Sergeant:
  • 416 Answers
Time to change charging system under fly wheel
did you have to jump this mower and use a car battery of high boost charger ? if so you burned out system
Posted on Nov 20, 2013
3 Suggested Answers
BAMOUT
  • 2478 Answers
SOURCE: My 2001 Murray riding mower's gas tank is
I've using years. I had a problem like your. I believe how good it works. Let dry for 24 hours. Two years no leak.2_1_2012_1_42_25_am.jpg
Posted on Feb 01, 2012
Testimonial: "Thank you!!!"
  • 2239 Answers
SOURCE: i have a 19.5 briggs and stratton engine on a craftsman model #917.270910. The starter turns engine then the engine hangs up not turning completely. briggs ans stratton mod#461707 type#0145 E1 code #
The decompressor is a valve lifter usually on the exhaust valve, the only adjustment is to correctly set the the valve clearances, if they are too slack the lifter will not activate.
Posted on Apr 21, 2013
Need a repair manual .pdf for a Briggs and Stratton Model 311707 Type 0132-E1 engine
H.A., Check the attached links,instruction and guides for Briggs and Stratton, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My 311707 0132 E1 Model Overview from PartSelect com
http://www.smallenginesuppliers.com/html/engine-specs/briggs_vertical_shaft_engines/276781SingleCylinderOHV.pdf FAQ Small Engine Specifications Briggs Stratton Specs
Briggs Stratton Small Engine Specifications
Jul 01, 2016 | Measuring Tools & Sensors
How do I remove the carburetor of a Briggs & Stratton model 287707?
remove the air cleaner assembly,then unscrew the 2 threaded bolts, should be 8mm head visable once air cleaner removed. disconnect fuel pipe,choke and throttle linkeges and backlash spring
Sep 26, 2014 | Briggs & Stratton Garden
Carburetor leaks after engine is shut off
Your carbs bowl float is sticking allowing the gas to continue to flow when the engine is not running.And if you say it is ruining into the engine..check the oil for the presence of gas..if so change the oil,oil filter and remove the plugs and cover the tips to stop spark..turn the engine over to blow gas from the cylinders using a rag to catch the fluid...now to the fix..either take the carb apart and clean all the parts but there is no way to know if this will happen again..this has happened to my Husky. The best and easy fix is to install a inline fuel shutoff valve..where you can get at it easily...Just shut it off and let the engine use up the carb fuel..and when you start it again turn on the shut off valve let it set until the carb gets full about ten seconds..then start the engine...just got to rmember to do this every time you shut it down...works well for me...good luck.
Feb 06, 2014 | Briggs & Stratton Garden
Battery does not charge
Check all the battery connections, if they look good replace the battery.
Nov 19, 2013 | Briggs & Stratton Garden
I have a 19.5 briggs and stratton engine on a craftsman model #917.270910. The starter turns engine then the engine hangs up not turning completely. briggs ans stratton mod#461707 type#0145 E1 code #
Apr 21, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you replace a condenser on a 16 hp Briggs and Stratton v-twin model-303777...type 1142-E1. Note:Engine runs fine for approx 30 min(until it heats up) and then shuts off & will not restart until...
The condensor is not the problem for they go bad upon not hold a charge. When the engine heats up and the engines dies out the problem may lay in the magnito's frame mounting from swelling from the heat, a loose mounting bolt(s). Or a Magnito that is ready to go out completely
Sep 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
104 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
