Question about Ovens
Chef Tronic Manual
Need Manual
How can I get a manual for a koolatron total chef ZO- 100 B
Did you do a Google search for this? You need to give correct information to get help. I did a search for the above, but didn't find the manual. I did find the oven under Koolatron Total Chef Oven Z100B. Look here: http://koolatrononline.stores.yahoo.net/koolatron-total-chef-oven.html. Call the company at 1-800-265-8456. Tell them what oven you have and that you need the instruction manual.
Dec 19, 2014 | Ovens
Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Apr 16, 2009 | Ovens
Chef Coronet Integra oven - no manual
Problem not solved, so I will just have to bumble on! Cannot afford the premium plan, but thanks - I have you on my list should something else happen! Thanks Gabrielle.
Mar 20, 2009 | Ovens
Magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Dec 18, 2008 | Magic Chef 9522 Electric Double Oven
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Missing my manual
I suggest you read this link before you use the self clean cycle. http://www.fixya.com/support/t241114-oven_will_not_heat#SameProblemContinued
I used mine for the first time two days ago on model KEBC147 and it will not heat now.
You might not want to try self-clean unless you have time to call for repair afterwards before
using your oven again.
Very disappointed in KitchenAid in Texas ...
DBN
Oct 24, 2008 | Magic Chef 9815 Electric Single Oven
MAGIC CHEF TIME SAVOR GLASS TOP
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Thanks.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
