Question about Caterpillar Skid Stear Loader
My cat 287b stalls when reving at a high rpm
New fuel filter, new air filters, clean fuel and it still stalls down/dies when trying to run at high high rpm
I have posted this before my engine stalls when put into drive and also reverse I have cleaned the egr valve replased the fuel filter cleaned tank filter still no good ps would a blocked cat do this...
We would need more info to give advice.
I doubt a clogged cat would cause the problem.
Have you checked fuel pressure, can you raise RPM in park, and does the engine die suddenly when you shift into gear ?
Mar 12, 2015 | Cars & Trucks
Why matiz high fuel consumption ?
run fault codes first .Check for faulty o2 sensors and check the air filter is clean. Check fuel pressure in the rail. check for blocked exhaust system (cat converter) check for correct tyre pressures and check the load carried and the speed being driven at . Check that the od is operational and that the motor is not over reving at speed this car in proper operating mode should be around 6ltrs per 100 klm's travelled
Jul 20, 2014 | 1999 Daewoo Matiz
2003 windstar stalls when driving, idles high in neutral, now 4 codes
ok so much done owell next is the mass air flow to be checked then the fuel regulator to check pressure and the fuel pump for pressure and then check the cat,s for back pressure wood be my next thing and Last is the how many Km,s does it Have ?sounds like filter needs lookin at in the tranny if she,s got High Km,s if not then check the intake for leaks it,s Plastic so don,t hurt gone this far Let me Know What Happens,s Thank,s
Apr 08, 2013 | 2003 Ford Windstar
I'm having trouble starting the car. When it idols the RPM's pulsates up-and-down and then it stalls. Once under way the car seems to run fine but without any warning it will die as I start to
check air filter, might be plugged, [dirty so engine is starving for air.] check fuel lines & filters, dirt blockage need replaceing, check for fuel leaks in lines etc, uses fuel & then sucks air causing it to stop, listen to see if fuel pump is running properly & not stuttering could be short in it's wiring
Dec 16, 2012 | 1994 Mercedes-Benz E-Class
Backfires when reving down. high RPM then let off
lean out the system by adjusting the mixture screw. either less fuel or more air. also check to make sure your air filter is clean, that can also cause that problem.
May 15, 2010 | Motorcycles
My sonata 2001 v6 automatic won't rev past 4000 rpm by any way (idle or by driving) sometimes will shut after trying reving by full throttling. The only code output to my code reader is u0000 and no check...
I would replace the fuel filter(every 35000 miles),check the condition of the air filter and check out the catalitic converter and feel the tail pipe to see if the flow seems clogged and weak when some one else gives it the gas.
My 2001 had to have a new cat at only 44000 miles. I had them install a "High Flow" type.
Oct 30, 2009 | 2001 Hyundai Sonata
'90 3.1 lumina euro idles ok but tries to stall when accelerated.
If the cat is red then it is probably plugged if the motor can't exhale it wont run at high rpm
Apr 11, 2009 | 1990 Chevrolet Lumina
Caterpillar Skid Stear Loader Logo
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
