Question about Lionel Trains Holiday Express G Gauge Train Set
Engine won't move
Hello, I have the holiday express G gauge set. the set lights, musci plays but the engine doesn't move at all. I have changed batteries, and nothing.
  • anthony martinez
    anthony martinez Nov 25, 2013
    hello,
    Well I got the train to run but only in reverse. I still can't get it to move forward. any suggestions?
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Sep 30, 2014 | Lionel Trains Holiday Express G Gauge...
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
How do I clean the tracks & wheels to stop the short circuit?
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 13, 2013 | Lionel Trains Holiday Express G Gauge...
Have a lionel holiday tradition express. Lights are on, but train won't sing or go forward. Changed batteries and nothing.
Nov 12, 2013 | Crafts & Hobbies
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
Dec 03, 2012 | Lionel 11000 Holiday Tradition Express...
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
Each yr my New Bright Holiday Express train gets slower and slower the longer it runs. Finally it just stops. Every thing else seems to work: lights, etc.Train shop specialist say its the engine, not the...
check the electrical current to the trans former , then check the out put from transformer, may not be getting adequate electricity flow to operate , and if you continue to operate under required current , it may damage engine and or transformer , gd luck
Nov 23, 2017 | New Bright Small Holiday Express Train
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
Dec 22, 2008 | New Bright 384 Holiday Express Animated...
Lionel Trains Holiday Express G Gauge Train Set Logo
54 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
