Question about ASUS DSL-N10 Wireless Router - IEEE 802.11n 1 x Antenna Ism Band 150 Mbps Wireless Speed 4 x Network Port Desktop
Want to change wifi key of my modem
My wifi used by some other so want to change wifi key
I am trying to pair my Bluetooth headphones to my ps3 and it asked for a pass key. Where do I find this?
The pass key is the key that you use to access your WiFi its usually on the bottom or the side of your modem unless you've changed the default password to something different.
Feb 18, 2015 | Radio Communications
Huawei modem speed up using wifi booster
Yes. You can definitely speed up your Huawei modem using WiFi booster. You can get WiFi booster at low cost online and install it at your desired location to speed up your Huawei WiFi modem. You can check the change in your internet connection speed after installing a WiFi booster by having a speed test at ScanMySpeed.com good luck.
Dec 26, 2014 | Computers & Internet
Find network key on sb6141
The term "Network Key or Passphrase" indicates your printer is asking for a WiFi password, but the SB6141 is not a WiFi capable device at all, it's just a Cable-to-Ethernet device. So then, you need to look at your WiFi router, which should be connected with an Ethernet cable to your SB6141. If this doesn't match your setup, you'll either need to get a WiFi router hooked up (that process will contain the answer to your question) or simply use an Ethernet cable for your printer.
Nov 09, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Changing security key on my modem surfboard wireless sbg6580
Use the default user name and password to login... then you can go to wireless tab and chamge the WPA key to whatever you want.
Sep 22, 2014 | Arris SURFboard SBG900 Wireless Router...
How do i block someone from using my wifi if they already have the access code
log into the router and change the access code (by that I assume you mean the wifi security key). Simple process , in the manual which can be downloaded from dlink.
Jul 13, 2014 | D-Link ADSL2/2+ Modem/Wireless Router...
Cannot connect with wifi on mobile.
For wifi connection:
1. Make sure that you have a working modem router in your premise.2. Turn the modem/router on.3. Select settings icon from your mobile phone.4. Select Wireless Connection or WI-FI connection.5. Select options, then select connect.6. You will be asked for the WEP or WPA key. This is depending on what is the security option that you selected in the modem settings. (for modem settings you can contact your internet service provider or OEM for the modem)7. If you are aware of your pre shared key, just type it in the password option from the mobile screen.8. Once connected, you can use the wifi as your active connection access.
Jan 14, 2012 | Cell Phones
How to connect wifi network in archos 28 internet tablet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
Dec 17, 2010 | Archos 28 Internet Tablet
How can i use wifi on my wa3002g4 modem
first check whether the wireless key( antenna symbol key) is on....
go to network connections->check available connections->connect
if you still have a problem contact your service provider
he must help you.... if they cant fix it change your service provider...
May 13, 2009 | Computers & Internet
ASUS WiFi-g
No, you want to connect direct to the Modem from your new computer. Look for the user's manual online and find out where the Wi-Fi switch is. Sometimes it's a Function key, where you hold down the Fn key and press one of the function keys along the top row. Look for a little "radio antenna" icon on F2, F3 or F4. On other machines it's actually a hardware switch, usually on the left or right sides.
Apr 22, 2017 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
ASUS DSL-N10 Wireless Router - IEEE 802.11n 1 x Antenna Ism Band 150 Mbps Wireless Speed 4 x Network Port Desktop Logo
16 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
