Question about Vehicle Parts & Accessories
Need a manual for this car remote starter remote
I have this prostart ct-3460 tw car remote starter and I can't figure out the remote. I have a 2000 jeep tj sport 4.0L that I've installed it in. The jeep won't start by remote and there's no information on this remote in the manual and don't know how to work it properly. There's some icons on the screen I don't know what they mean.
How to install the remote stater prostart on a toyota corolla
1. Go to the manufacturer's website and find the exact product you have and want to install.
2. Download the installation manual and READ it thoroughly
3. If you don't understand how to install it, find a qualified professional installer locally and have them install it correctly
4. You don't want to mess up your car's wiring; it can lead to untold misery
Dec 07, 2014 | 2000 Toyota Corolla
Programming a remote for prostart 3460 tw
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 21, 2014 | Televison & Video
I have to install a remote starter ProStart 3271 ct J need to chima Electric to complete installation I need to connect the wire starter kill output
talk to prostart on custom car hacks.
only th
ey can help., after all its THEIR design.
when stuck far from home , dont expect some pro to figure out your custom wiring , for cheap, for fast or even possible.
dont hack cars! and save tons of grief and cash,,,,
unless its a toy. then hack away.
looks like you are already in trouble. sure.
(done many)
Sep 13, 2014 | 2001 Toyota Corolla Sedan
How do I reprogram Prostart remote starter/car alarm after replacing car battery?
Try turning the Prostart off, then on with the little toggle switch. Check that the hood pin switch is working as it should
Dec 03, 2013 | Cars & Trucks
Car remote start
hi
you need to find the wiring diagram
bcz remote starts normally have 3-5 replays
however there are other types on the market that can be operated via the factory remote only
no alarm module required
maybe the manufacturer of the device can help
cheers
Nov 07, 2013 | Vehicle Parts & Accessories
Need help with the 3 pin harness from a prostart car remeote starter ct-3460tw how to wire to my 2000 jeep tj sport with manuel trans
It looks like those are the Lock/Unlock wires with a ground for power locks that rest at ground. Your ok without them just finish your install. Good luck Sir.
Nov 03, 2013 | Vehicle Parts & Accessories
Hey MECP guy, what a job you're doing; THANKS. I want to buy the Prostart CT-5472W for a 2004 Lincoln Navigator. I also want to get addt'l modules like DEI 504D shock sensor 506T audio sensor
Yes, I frequently use DEI modules with Audiovox( Prestige and Code) alarms and remote starters. I just have to hardwire them to work with the systems.
Oct 26, 2012 | Vehicle Parts & Accessories
Looking for installation manual for a prostart ct-3100.I would like to install it in a 2000 gmc jimmy
http://www.engines911.com/asdocs/CT-3100_ig_en_h100s100v100_010810.pdf
here is the information you requested, good luck on the jimmy, you will also need a passlock 2 bypass modual and a door lock polarity inverter, let me know if you need them as I stock these items
Dec 10, 2009 | 2000 GMC Jimmy
Need install manual
http://www.engines911.com/asdocs/CT-3200_ig_en_h370s380v150_040902.pdf
copy and paste into your browser... should be able to download and print...
Jan 06, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
228 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
