Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Briggs and Stratton lawnmower engine
Briggs and stratton engine model 445677, type 0476-El, Twin OHV 24 hp.
freetek
  • 5568 Answers
SOURCE: Gasket for briggs and stratton
I recommend  Jack's Small Engine Repair; they have always had the detail part I needed and their prices are among the lowest.
They will probably have an illustrated parts page for your model.
Jack's
Posted on Mar 22, 2009
  • 376 Answers
SOURCE: Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
Posted on Jun 12, 2009
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
SOURCE: How much oil goes in a briggs and stratton Model
maintenance instructions says 36 oz.
Posted on Apr 25, 2010
eugbug
  • 479 Answers
SOURCE: briggs and stratton 5 hp engine won't start
An engine not starting can have many causes but it is usually due to lack of fuel being sucked into the engine or no spark.
Remove spark plug. It should be damp, if it is wet, the engine has been flooded and should be left for a few minutes for the fuel to evaporate. Replace lead on the plug and hold the threaded part against the engine somehow. Make sure you don't hold the lead in your hand!
Pull start the engine and ensure there is a spark.
Posted on Jun 21, 2010
Briggs and Stratton 23 hp lawnmower engine exhaust valve keeps sticking
it is possible that the valve stem is bent or has a build up on the stem that is jamming in the guide. Pull the head and replace the valve.
Sep 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Bent push rods both cylinders,engine # 445677-0827-B1
You can find a manual, free of charge at www. briggs & stratton.com. click on manuals and put in your model and type and its free to d/l. You can then print it out if so desired.
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Roland W VanLue
Roland W VanLue
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
