Question about Pioneer Televison & Video
No video for about 10 minutes after set turned on - has occurred since power outage. I replaced cable box, but the problem persists.
I don't know if the problem is with the TV. Could it be the video cables that connect the TV to the cable box? Other components, such as DVD player work fine - it is only through the cable component that there is a video delay.
  • 115 Answers
Power supply faulty check faulty coponent
Posted on Nov 19, 2013
tvtek
  • 1284 Answers
SOURCE: "No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Posted on Feb 08, 2007
simplemitch
  • 752 Answers
SOURCE: poor picture with hdtv Hitachi 37HDL52 plasma
What EXACTLY is wrong with the picture? Is it black and white? Green? not there? distorted? need info...
Posted on Sep 20, 2007
SOURCE: blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Posted on Oct 26, 2007
SOURCE: Westinghouse LVM-37w1
I have had this problem since about superbowl time. If I powered the set off, waited 15-20 seconds, and then powered on, it would work again for a while. Repeating this drill a number of times would lead to stable operation. We resorted to a course of turning on some XM music from DirecTV when we weren't watching. I tried a technician knowledgeable on this set, and it would have cost $500-800 to repair the set. We learned from different forums that the likely culprit was either the power supply board or the LCD controller. We also picked up the rumor that Westinghouse had quit making replacement part. It would seem that the management of this organization has a death wish. TO THE CHASE: shopjimmy.com is now selling parts from canibalized sets. They have a non-DOA warranty and a good return policy. A power supply from "Jimmy" solved my problem. I have one important hint: To remove the back, take out the obvious screws and the base. Then remove the ~5/8" rods that protrude from the bottom. There is a screw up inside each rod.
Posted on Oct 22, 2008
  • 35 Answers
SOURCE: TH-42PZ77U Blinks 10 times (worked fine for 1 year)
The P, PA, DH, H or DT board may be defective. Email for some help...
Best regards
gysgt2u1@yahoo
Posted on May 08, 2009
Reset after power outage
some of these had resets others reset after you unplug it for about 20 minutes and replug it in. some older models you had to hold in the power button for 5 to 10 seconds.
Apr 23, 2014 | Pioneer VSX-11 Receiver
Bad line ge nomogram
You need to think of these ovens as electronic devices. If you get this message after a power outage, it is behaving just like your cable box or internet router when they have functional upset from a power outage. Turn the power off to the oven at the electrical box for 10 minutes then turn it back on. The oven should cycle up and then work. Mine did!
Mar 17, 2014 | GE Monogram ZDP48L4GHSS Dual Fuel...
Our nintendo wii will not turn on ever since we had a power outage which honestly only lasted like 10 seconds
Some devices can have serious problems when a power outage occurs, i would reccomend contacting nintendo support about the problem.
Mar 08, 2011 | Nintendo Wii Console
HP 4200 Laser Jet Printer Error Code 82.0180 EIO 2 Error
The error message "83.0180" shows that an EIO error has occured.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
May 07, 2010 | HP LaserJet 4200 Printer
My 6 month old tv went out during a movie we were watching and when i turn it back on all i get is a blank black screen. what do i do? It is a 42" Element
Hi Chris!
Please disconnect all the cables from the TV then reconnect them back after two minutes. Make sure that the power cable from the TV is directly connected to a functional wall outlet. Next, turn ON the TV and reset it to the original factory settings. You may also try connecting a different video source such as cable box, DVD player, Blu-Ray player, Playstation, etc to the TV to check whether the issue persists with all the video sources.
If the issue persists with all the video sources then service may be required.
Jul 12, 2009 | Televison & Video
I have an RCA 50 something inch projection set that is about 10 yrs old. I had a cable outage this morning and now that the cable is back on the cable box says STANDBY. I called the cable company who tells...
I found out the model number is P52820BL and after researching on the internet further I found this set has a problem with power outages. I found a site that told another person with the same problem that it would take about $350 to fix - if it could be fixed - and there is no guarantee it would work for long after. Therefore, we decided not to bother fixing it. We are getting a new one.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
No power
I have two of these where I work and have seen this problem occur after power outages. I've been able to resolve it by unplugging the power and usb cable and letting it sit for 10-15 minutes . Plug everything back up and it works again (until the next power outage)
Jul 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Televison & Video Logo
32 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
