Question about HP Photosmart C4280 Aio Printer
Clogged print head cleaning tinteiros
Tinteiros Don't Have Ebay Account Want To Buy tinteiros Canon Head Cleaner
    New Friend:
  • 87 Answers
This printer photosmart c4280 do not have print head fixed in printer, The print heads are in cartridges, replace with original ones.
Posted on Nov 19, 2013
  • 537 Answers
SOURCE: print head cleaning utility.
I cannot remember if the tools menu is embedded in the properties of the printer driver. The previous poster I believe is correct. If it does not appear, go to start, run, all programs, then select the HP or Hewlett Packard section and look for an HP Toolbox or similar utility that will have options for cleaning/aligning/testing the printer..
Posted on Feb 25, 2008
FatrCat
  • 9 Answers
SOURCE: clean officejet print head
You can get very good results in reviving the HP Officejet 7100 Series printheads simply by placing them in a shallow plate or dish with about 1/4" of hot water (ideally distilled water). Soak the nozzle face (bottom) for at least 5 minutes before drying and testing; repeat if needed for really clogged heads.
Posted on Mar 12, 2008
dante777
  • 623 Answers
SOURCE: How do I clean the printer head for a HP deskjet 6540?
Have a look at the manual for this printer:
http://h10032.www1.hp.com/ctg/Manual/c00251861.pdf
Section 8.5 and 8.6 describes very detailed how to clean the cartridges automatically and manually.
If you have, use latex gloves, so you don't have that mess of ink on your fingers.
Enjoy!
Posted on Dec 23, 2008
websnail
  • 419 Answers
SOURCE: HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Posted on Feb 14, 2009
gwbm
  • 353 Answers
SOURCE: Epson C86 print head/cartridge head won't move.
Hi Beverley
There is some confusion here. You say "ink sponge needs replacing" in an Epson C86 (although you have your query posted under HP Officejet 5610!) - I presume you mean the waste ink pads. If so, you need to dismantle the printer - the pads are not under the print head but deep inside the case. I can provide all the information you need to complete this task if you really want to do it yourself. Please post a new comment requesting this assistance if you do.
Posted on May 06, 2009
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Won't print...says it is printing but doesn't
printer has just been left unused for some time? You probably just have an ink clog.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the MagicInkjet Flush kit to soak the print head and you should be printing again like new.
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 23, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
How can you clean the printer but clicking on
Hi
If yourPSC 1210v printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your HP 56 57 still has ink? Empty they are about 30g Each 1g over that is 1ml of unused ink.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a littleMagic Inkjet Flush to soak the print head and you should be printing again like new.
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 02, 2009 | HP PSC 1210v All-In-One InkJet Printer
CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that is 1ml of unused ink.)
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little Magic Inkjet Flush to soak the print head and you should be printing again like new.
HTML clipboard HTML clipboard HTML clipboardYou can read more here: How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
Nov 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
My canon pixma ip1980, does not work the power ON, the cartridges were fine( they are new). please help me.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the print head?
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Got a new computer and the printer may not be set up correctly its not working
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog?
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | HP Photosmart C5180 All-In-One InkJet...
Prints like it is running out of ink, but it is a new cartridge. Some sentences are printing, others are blank, or partially printing.Followed instructions to align and clean nozzles. Doesn't help.
HTML clipboardIf you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Dell 946 All-In-One InkJet Printer
After cleaning the nozzles, the quality of print is still very poor. What should we do?
HTML clipboard HTML clipboardHi
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Canon Office Equipment & Supplies
After replacing cartridge in dell 810 the colours printing wrong
Hi
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
MIXED COLOURS
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
PRINT TEST SHEETS FOR USE WITHMagic Inkjet Flush
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
Canon pixma 3000 won't print red
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the magenta *red.
But provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Good Luck!
Tinteiros (Ebay)
Oct 28, 2009 | Epson Stylus C86 InkJet Printer
HP Photosmart C4280 Aio Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
