Question about Sewing Machines
Have a BE-090e-ac embroidery machine. need help with how to wind bobbin
    Champion:
    Habit-Forming:
  • 201 Answers
Please you bought a separate bobbin machine. And ask near experience tailors.
Posted on Feb 18, 2014
4 Suggested Answers
SOURCE: Winding the Bobbin
If you have a top winding bobbin on the right hand side it may be that the winder is seizing up, you must put a drop of oil now and again down the spindle otherwise it goes dry very quickly at high speed.
Posted on Jan 21, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
ju222dy
  • 8 Answers
SOURCE: Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Posted on Aug 09, 2012
My endless automatic bobbin winding for embroidery doesn't work?
Are you using the bobbin especially designed for that function? Did you use the plastic template? Setting up for endless bobbin winding is quite involved, and it's easy to skip a step and make a mistake. It took me several tries to set mine up.. Frankly, once I finally got it set up, I wasn't thrilled. It doesn't hold a lot of thread, and it was quite frequently interrupting the project to wind more thread on the bobbin.
Jan 10, 2016 | Singer Quantum XL-5000 Computerized Sewing...
Bobbin doesn't wind properly
some do need a little finger help to guide the thread across the bobbin so it lays flat
Apr 02, 2015 | Brother PE-500 Embroidery Machine
When I go to fill my bobbin spool, the machine just beeps at me. I've tried everything. Please help!
If you try to wind the bobbin with the embroidery unit on, you need to send a design to the machine before trying to wind the bobbin. If the embroidery unit is off, you should wind the bobbins without any problems
Aug 22, 2011 | Singer CE-200 Quantum Futura Computerized...
Improper bobbin winding
Check the manual for your machine to make sure you are feeding the thread through the correct guides and connecting with the bobbin as indicated.
Mar 10, 2010 | Sewing Machines
My white thread from bobbin shows thru embroidery
flip your bobbin
when I hold my bobbib in my right hand and pull the thread with my left hand the bobbin spins counter clockwise, this is how i put it in the machine
Do you wind your own bobbins if so make sure you wind evenly
I order a box of 100 pre wound bobbins from Brother
Sep 10, 2009 | Baby Lock Esante
Bobbin won't wind.
If this is new, ask at the shop where you bought it if they can show you.
As Janome dealers, we give several free lessons to familiarise customers with their new machines, it is good relations and keeps customers happy....your Brother dealer ought to be pleased to help, ....heavens, you may even want to go and buy some thread, or tell a friend how helpful they were afterwards !!
Go on....ring them and ask !!
Aug 27, 2009 | Sewing Machines
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Machine embroidery
You should always use proper Bobbin Thread for embroidery - not a bobbin wound from regular dressmaking thread. You are right, the special bobbin thread is thinner so that the embroidery thread will be pulled to the underside and you get a nice shiny embroidery on top with no bobbin showing through. Wind yourself 6 or more bobbins at a time of bobbin thread to always have some on hand, or buy the pre-wound L size ones.
All embroidery machines - no matter what brand - recommend using bobbin thread for embroidery. It is readily available at all sewing stores, probably even Spotlight would carry some. If you get stuck for a supply, try overlocker thread.
Dec 04, 2007 | Husqvarna Designer I
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
