Question about Garden
Jd#la115 does not turn over past compression stroke
John deere model #LA115 does not turn over past the compression stroke unless i turn it by had a little past the compression stroke. Then it will start up.
    Novelist:
  • 180 Answers
I'm guessing a "weak battery" is the problem. Sometimes a fresh new battery can make a piece of equipment run "like new"..... Also, you might make sure battery is high enough capacity... If all this does you no good, I'd guess you have a "tired" or worn out starter...
Posted on Nov 19, 2013
wireguy212
  • 1627 Answers
SOURCE: How do you reset the service reminder on a John
Open the hood and you should find a yellow push button,turn the key on,then push and hold the button in for 5 seconds or until the service reminder goes out.If yours is an early model with no push button then it will go out by it's self after 5 hours are put on the hour meter.
Posted on Aug 07, 2010
elix0411
  • 3530 Answers
SOURCE: Where can I get
For the manual, you can click on this link. For the printable maintenance sheet, you can click here. It also it includes parts list.
All the best!
Posted on Sep 29, 2010
  • 252 Answers
SOURCE: right wheel turns but the left one will not on
hi there
have you had the r/h wheel off at any time ? please check that you have the axle / hub key in the r/h wheel hub
if it is and the l/h one is in as well and the bypass rod is disengaged and it still does it
might be a internal hydro box problem
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet
search - la115
select pictorial , then select transmission , and trans page will open up with a picture of trans think model is tuff torq k51 but not totally sure - model of box will be on trans somewhere
might pay for your local shop to take a look
cheers pauly46
Posted on May 22, 2011
SOURCE: why does my john deer la115 make a loud screeching sound when i take my foot off the brake
Bad belt or belt tensioner. Shut it off and look underneath for problems.
Posted on Apr 21, 2012
  • 42546 Answers
SOURCE: My John deere la115 blowing gas out of intake
suspect a leaking inlet valve probably from badly adjusted tappet setting
Posted on Jun 17, 2013
Have a 2009 John Deere LA115 and need a belt diagram.
For a belt (replacement) diagram, contact John Deere directly.
Apr 18, 2017 | John Deere Garden
Where can i find a John Deere la115 wiring harness diagram?
The John Deere site has the wiring harness diagram on the LA115 parts diagram in the Electrical section (section 40, page 19). Start here: https://www.deere.com/en_US/parts/parts.page and select the Parts Catalog. http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt is where I ended up. The carburetor is in section 30 (Fuel and Air), page 10.
I hope this helps.
Aug 03, 2015 | John Deere Garden
John deere riding mower wont turn over unless plug is out
IF you have to remove the spark plug to get the engine to crank, check to see when the motor is in the compression stroke and go just past that point and try again to see if the motor cranks with the spark plug back in. 3 of 4 piston motions are not related to compression. If it does not move then the starter does not have enough torque.
May 13, 2015 | John Deere Garden
Is there any manual for a john deere riding lawn mower model # la115
if you look up "john derre riding mower" blog or club, I'm pretty sure you will eventuality find a bunch of lawn mower enthusiast, with alot of time and resources on their hands. Most of the time you can find rare parts, paint, manuals and lots of extras.
Jul 16, 2014 | John Deere Garden
What makes my john deere 2030 diesel engine fire
Super high compression ratios in the combustion chambers which ignite a highly COMBUSTIBLE, not overly FLAMMABLE fuel mixture. How they get the mixture to fire at or before top dead center of the compression stroke I have no idea.
Nov 11, 2013 | John Deere Garden
John Deere riding lawn mower model LA115. Light tension long spring came loose on carb. Where does it hook up to
I need more info. I need engine make, model, code, date of manufacture, etc. It sounds like a governor spring. Is it wrapped around a linkage going from carb to governor on engine? If it is, it goes in the same hole the likage goes. But to be sure get me the info above and I will check for you.
Aug 01, 2013 | John Deere Garden
Right wheel turns but the left one will not on john deere la115
hi there
search - la115
cheers pauly46
May 21, 2011 | John Deere Garden
My LA115 started up and started sputtering and black smoke was comeing out and then it died and now it will not start back up
Sounds like a broken piston ring, if you take the plug out is there any compression when you turn it over?
Aug 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do you reset the service reminder on a John Deere LA115
Aug 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
