Question about Vacuums
Beaterbar wont turn and motor just hums like its locked up
    Problem Solver:
  • 9 Answers
It might need a new belt, thats what drives the beater bar from the motor
Posted on Nov 19, 2013
Beater bar won't turn
The belt may look ok but they lose elasticity and should be replaced at least every 6 months to deep clean properly. The beater bar may have debris stuck in the endcaps which keeps them from spinning freely. Depending in what vacuum you have, some have a separate motor which turns the beaterbar. If yours has a separate motor it could be the motor, the switch, the wiring or a variety of other possibilities.
Mar 26, 2014 | Vacuums
Beaterbar won't turn
just go to your local grocery store and purchase the type of belt that it says under or on the back of the cleaner
Brush won't rotate
Undo the screws for the housing pull out the beaterbar and remove any string or hair. Put a new belt on the beaterbar then put the bearings back into their slots and gently put the other end of the belt over the motor shaft.
Nov 30, 2013 | Vacuums
Henry hoover
That means you had too much hair in your beaterbar or that you had the vacuum set too low to the floor. The beaterbar stopped turning and the rubber belt was slipping creating friction and heating to the point of melting. When you vacuum check often that the powerhead (beaterbar) is moving. If the belt ever slips it stretches or melts in half and must be replaced.
If you were referring to the motor then there isn't much you can do but replace the motor.
Oct 17, 2013 | Vacuums
The pump motor hums but wont start
unplug machine and see if you can turn the brush in the head. if the brush can be turned then the motor is probably burnt out. if the head is hard to move then there is something stuck in there preventing the motor to turn. there is usually a belt from the head to the motor.
hope this helps
Jul 12, 2011 | Vacuums
I own a Hoover Steam Vac Plus w/ Rotating Brushes (model#F5871-900), when I turn on the power I hear a medium-loud hum coming from the motor area and nothing works. What could be the issue?
the motor sounds locked up. Water gets in there and rusts the pieces together. The motor could be replaced, but probably not repaired.
Jul 04, 2009 | Vacuums
Can't lower beater bar - so won't pick up lint
the small tube under the hover goes stiff and the beater bar wont go lower enough so youve got to get small tube under hover soft and than set beaterbar to the ground let it go hard and may solve your problem many thanks nick...
Nov 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
