Question about Janome Memory Craft 9000 Computerized Sewing Machine
Need a PDF version of the manual for empisal s4d overlocker
What is the tension settings on the empisal model S4D
Tension on sergers will vary based on the type of stitch you want to create. For basic overlocking, the tensions are usually set at the midway point. However, every machine is different, so some tweaking will most likely be required to get the stitch where you want it.
Empisal S4D Instruction Manual
Nov 03, 2016 | Sewing Machines
NEED A MANUAL FOR OVERLOCKER s4d
sorry but without make we can't even begin a search for one
Apr 23, 2015 | Sewing Machines
Can my Empisal overlocker do n roll stich?
instruction manual for empisal overlocker s4d
Dec 28, 2012 | Sewing Machines
I want to know how to hem with my empisal s4d overlocker
check with
sewvacdoctor.com
a1sewingmachine.com
you may need to contact these websites by email
also try youtube & ehow for video's
Apr 16, 2012 | Sewing Machines
My manual got lost, need to remove needles, I bought a Empisal Model S4D Overlocker but the manual or CD got lost and I need to get one
look on you tube for overlocker parts instruction.generally the needle is removed by loosenening a little screw which is pushing on the needle from the from.
sewingmanual.com has manuals for sale
Sep 14, 2010 | Yamata FY812 Mechanical Sewing Machine
Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
Jul 18, 2009 | Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
