Question about Sewing Machines
Esante baby lock ESe2 dog feed won't feed material.
  • Sewing Machines Master
  • 7,365 Answers
Check to see if the feed dogs lever is in the up position for sewing, if not move the lever to the up position, if the feed dog lever moves and it doesn't make the machine sew, then the feed dogs need to be checked.
Posted on Nov 19, 2013
MakikiChris
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
  • 323 Answers
SOURCE: ESPIRE SEWING MACHINE - MODEL ESp baby lock
Take it back to where you had it repaired and ask the dealer to make it work under his warranty. Maybe he can tell you exactly what's wrong with your machine. Usually it is a pressure problem or the feed dogs are filled with lint or they don't rise high enough above the needle plate to work. Take off the needle plate and check them.
sewman7
Posted on Jul 18, 2008
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 3 Answers
SOURCE: i have an esante ese2.
you will need a card reader, and a blank compatible babylock/brother card.
Posted on Jan 28, 2009
SOURCE: won't work at all-esante ese baby lock
Check that the button used to snip your thread at the end of your seam is not stuck. Mine will sometimes stick and if I just touch it again it will again activate and the red start/stop button will work again.
Posted on Nov 11, 2009
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
Feed dogs do not pull material through machines when sewing
then the feed dogs need to be checked to see if they need replaced or adjusted
Apr 11, 2015 | Baby Lock Esante
How do you place an embroidery design from a card into the machine memory? I have a ESe2. Thanks!
For the Brother NV1500 (aka Babylock Esante ESE2).
Bring the embroidery design onto the screen.
Press the save button in the upper right of the screen.(it looks like a pocket)
See pages 141 to 143 of your instruction manual "Saving Embroidery Patterns In The Machine's Memory"
Mar 18, 2014 | Baby Lock Esante
Feed won't move fabric
Feed dogs in the up position? Most machines have a switch to lower the feed dogs for free motion or embroidery! If switches in correct position then remove your stitch plate and clean out all fluff built up between the stitch plate and the feed-dogs. If none of these: dealer time.
Dec 02, 2013 | Baby Lock Esante
Looking for a babylock esante manual. ESe2. The
I have a manual for the ESe2. If you still need it let me know
Nov 16, 2009 | Baby Lock Esante
Feed dogs will not go up
remove the embroidery arm and before yo place the sewing box attachement move the feed dog switch to the left/up position. (its located on the frontside of the machine, which is visible when you remove the embroidery arm.
Jan 06, 2009 | Baby Lock Esante
I have an esante ese2.  is there a way to get downloaded images onto the machine?
Dec 25, 2008 | Baby Lock Esante
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Nov 29, 2008 | Baby Lock Esante
Sewing Machines Logo
112 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
