Question about Radio Communications
I have a pair of RCI-1001 walkie talkies cant get to recharge
Neto
  • 123 Answers
SOURCE: configuring audiovox GMRS1072CH walkie talkie
With the issue of 240V if the charger has not a Voltage switch, you will need to find another charger/transformer with the same Voltage/Amps ouput that works with 240V.
For Vox operations, this feature works independly form channel, you should choose the channel# and code # first, to match both radios, and get them communicate, then the Vox feature.
In Some radios the VOX feature works with an external audio accesory, in other radios works with out it.
Basically if this radios works without it, you should see that the radio transmist by itself when you speak direct to the radio, and stops transmiting 1 or2 seconds after you stop talking.
Good Luck.
Posted on Nov 21, 2007
AvioriX
  • 689 Answers
SOURCE: oregon scientific walkie talkies
Hi Neil
You can obtain the Owner's Manual (Contains simple instructions) from link below
http://www.expressfix.net/manuals/2WayRadios/OregonScientificTP329
Posted on Sep 06, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
Posted on Jul 01, 2009
  • 56 Answers
SOURCE: Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Posted on Jul 23, 2011
How to fix a motorola fv200?
these are one-way radios. no service, no spareparts. just trough away and buy new
Dec 18, 2013 | Motorola Walkie Talkie 2-Way Radio
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
I am trying to pair my motorola walkie talies
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
You will need to program the frequency, code and Qt filter (if any) to match. For basic operation set the frequency and then set the code and Qt filter (if any) to off (zero).
Best regards.
Apr 14, 2010 | Motorola Walkie Talkie 2-Way Radio
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Jun 17, 2008 | Columbia Telecommunications Group FRS 22...
Radio Communications Logo
90 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
