Question about Salton Melitta Coffee Bean Burr Mill Grinder
Cg 4 grinder
What is the setting for flat bottom drip coffee?
The Senseo doesn't have apouring stream anymore just a drop and only 1/2 oz. of liquid comes out.
Your coffee machine grinder need to re calibrate .Coffee power is too fine thats why coffee dripping .just rotate the grinder setting towards the course grinder
Jan 28, 2015 | Coffee Makers & Espresso Machines
Why when grinder is on finest setting
Did you clean the grinder before using it? Did you run a 1/2 kilo or so of junk beans through to clean out any oil/grease that was in the system from manufacture? How old are the coffee beans? If you grind at a 4 and run it through the drip machine, does the coffee still taste off?
Apr 30, 2014 | Mahlkoenig K 30 ES Grinder
How to remove blade 0f krupps 203 coffee grinder and clean the motor
On the bottom of the Grinder, You will find several Rectangular holes. With a flat screwdriver push tangs to release bottom. In main shaft, there is a small slot for a flat screw driver. Inseret proper dcrewdriver in slot and turn blades counter clockwise. This should remove blades..
Jan 25, 2011 | Krups Burr Coffee Grinder
While the coffee is brewing without using the grinder feature, coffee overflows onto the counter. About 1/2 of the coffee goes into the pot while the rest spills over. I have cleaned residue from the lid...
overflow problem possible causes: 1) water is over the "10" marker, 2) no filter in basket 3) too much (or too fine) of coffee in the basket -- does not drain. Also make sure the "spring" on the bottom of the basket is not stuck (the one that lets you remove coffee carafe without dripping coffee.
Jan 17, 2011 | Cuisinart Thermal DGB-600 Grinder
Hi. On the Breville CG10 coffee grinder, is the higher the number the finer the grind or the other way? Thanks.
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Aug 21, 2010 | Breville Coffee Makers & Espresso Machines
West Bend Lifetime Stove Top Coffee Maker This is a nice heavy stainless steel coffee maker, probably from the 50s or 60s. It has four parts; a carafe that sits on the stove, a piece that fits on that with...
Not to sound like a knw it all, but we have a pot just like this. You have to boil the water in a seperate kettle and pour it in the pot. This is a drip pot, not a perculator. It will make the best coffe you've ever had.
Jun 20, 2009 | Coffee Makers & Espresso Machines
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Salton Melitta Coffee Bean Burr Mill Grinder Logo
46 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Anthony Turner
Level 1 Expert
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
