Question about Husqvarna Garden
My YTH24K48 is blowing the 20 amp fuse,
My YTH24K48 2008-2009 is blowing the 20 amp fuse, I jumpered it out with thin gauge wire and It starts, as soon as it reaches RPM it blows my jumper, continues running and the pto continues to work but will not start again until the fuse/jumper is replaced. When they key is in the on position the Jumper does not blow, Only when the tractor is at operating rpm,
    Scholar:
    New Friend:
  • 61 Answers
Have you or can you gain access to a wiring schematic/diagram of the machine and specifically the fuse your referring to and all of the components it powers? If you can I'm quite sure I can help you. Sometimes the dealer/employees will photo copy the pages you need and more so if you offer to pay them or tip them for what you need. Get back to us.
Posted on Nov 26, 2013
4 Suggested Answers
riceski
  • 1851 Answers
SOURCE: Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Posted on Jul 06, 2010
  • 6468 Answers
SOURCE: John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Posted on Mar 29, 2012
  • 6468 Answers
SOURCE: Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Posted on Apr 24, 2012
1998 Saturn sl1 keeps blowing 30amp cooling fan fuses. it runs for maybe 20 seconds then fuse blows
The cooling fan motor is likely drawing to much current because it is worn out.
May 18, 2016 | Saturn Cars & Trucks
How do I repair or replace a defective gas gauge?
It is in the instrument cluster, which has to be removed to replace the gauge. It cannot be repaired. Did you first check the 10 amp METER fuse in the fuse panel?
Now let me say, that when the gauge quits, it is more often a fault in the sending unit in the gas tank, and not the gauge. Here is how to find out if your gauge is good: Find the fuel tank electrical connector, and pull it apart. You will need a small jumper wire. Find the blue wire in the body side of the connector (not the fuel tank side). Put the jumper wire into the blue wire terminal, turn the ignition key to on not start, and ground the jumper wire to a metal frame piece. Someone needs to watch the fuel gauge needle while the wire is grounded. If the gauge in the dash is good, the needle will move. It will probably go to either full or empty, but if the needle moves, the gauge is good and the fault is in the sending unit in the tank. Don't give up testing until you are sure the jumper wire is being grounded good to the frame. Just touch the wire to frame and watch the needle movement, once sure, stop so you don't blow the fuse. If the needle doesn't move, first check the 10 amp meter fuse. If fuse is good, it must be the gauge.
May 30, 2015 | 2000 Kia Sportage
New fuel pump, ccrm and fuel filter and still blowing 20 amp fuel pump fuse
If the components are all good, then check wiring connectors and wiring circuits, it appears the problem is after the ccrm. wiring from ccrm to fuel pump. For testing you should be able to use jumper wire with inline 20 amp fuse, from voltage to fuel pump connector, to see if it will run w/o blowing the fuse. As you can see from ccrm to inertia switch there are two connectors. From inertia switch to fuel pump, one connector. There are many ways to test. With connectors unplugged, you could use a test lite connected to battery voltage, touch correct wire terminal, if lite comes on, that circuit is going to ground, somewhere.
See that one wire that goes down, wire circuit from ccrm to inertia switch, that wire goes to pcm, I believe it to a monitor circuit, the pcm monitors the voltage on that circuit.
Aug 01, 2017 | Cars & Trucks
I have a1988 chev 1500 that blows the 20 amp gauge fuse
I've seen fuel gauge wire from tank sending unit shorted out and blew gauge fuse
Nov 08, 2012 | Chevrolet Cars & Trucks
What the codes
You want delay fuse instead of fast-acting fuse. Look for delay on product description.
Since the motor has a high amp draw when first starting, then that means surge of heat traveling over wire.
Fuse trips when sensing heat.
Delay fuse will accept high heat for longer period of time before tripping.
You have 1 Hp 6K321 motor from WW Grainger. You can contact grainger.
http://www.grainger.com/Grainger/DAYTON-General-Purpose-Motor-6K321?Pid=search
I recommend that you use 12 gauge wire and 20 amp fuse. Over-sizing wire will save heat loss and prevent damage to motor, and heat damage fuse box.
If you use smaller 14 gauge wire and 15 amp fuse, the motor will heat the wire, especially if length of wire is longer than 100 feet from fuse.
The motor has thermal protection, so motor is not overheating.
The wire is overheating.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Sep 27, 2012 | Dryers
I installed a planet audio TW402 amp in my car. i put this amp last summer. when i first put it in my car with an sony xplod sub. i had a very small 12 gauge power wire and ground wire. but still it worked...
It could have to do with how your speakers are wired. If you have 2- 4 ohm speakers and they
are both wired to one terminal (RIGHT OR LEFT) on the amp, you have a 2 ohm load and most amps are rated at 4 ohms.
Go to this site and use #58 on the right sidebar to see if you are wired correctly.
http://www.bcae1.com/
Mar 14, 2011 | Planet Audio TQ402 Car Amp
So i hooked up the amp useing the pre-existing 8 gauge wire with a 30 amp fuse it worked for about and hour and started blowing the 30 amp line fuse. i replaced the line from 8 to 4 gauge and installed an...
this sound like a case of arcing power wire it happens very very easy if u use cheap wire especially from walmart. whatever u do keep using fuses and get a batt test asap. if u take out the fuses ull burn the amp like no other and plobably burn out the power rails which will be cheaper to buy a new amp after that
Oct 05, 2010 | Lanzar VIBE266 Car Audio Amplifier
Automotive wire in line fuse keep blowing fuses
sounds like eithor over draw or short
yes you can over draw the wires
Dec 21, 2009 | LG Art Cool LA1000PR Air Conditioner
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Garden Logo
247 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
