Daewoo dsa 180l - Heating & Cooling
Does air conditioner daewoo dsa 129l have a.reset button? If so where is it in picture format please . I lost the remote .
Did you also lose the manual that came with your unit? Check that out for answer - if lost go to website for download.
Sep 26, 2015 | Daewoo Heating & Cooling
I have problem
Hey, we all have problems. What's yours? You weren't very specific.
May 09, 2011 | Daewoo DSA-122L Air Conditioner
FOR THE REMOTE CONTROLLER (P.N. 3108402300) I
if the remote is a slide which reveales the controls the battery compartment is under that cover
May 02, 2010 | Daewoo DSA-122L Air Conditioner
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
Daewoo split system model DSB-242lhg. Wont work on heat green light is on but no hot air
Is the unit in heating mode? If so, are the filters clean? Have the system repaired if you cannot fix the problem.
Mat
Jul 15, 2009 | Daewoo DSA-122L Air Conditioner
My mini split shows f8 and turns on/off alone
The unit is going off on a hi temp .Can you leave it off for a while and then it will start up if you turn it on?I would be checking the fan motor to see it will run alone when the unit stops.Also check and see how hot it is at that time.
Apr 05, 2009 | Daewoo DWC-073C Air Conditioner
Replacement remote
You can find the nearest dealer here; http://www.e-daewoo.com/customer_service.asp Hope this helps :)
Apr 07, 2007 | Daewoo DSA-122L Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
