Question about 12Volt Toys
One back wheel is stuck - 12Volt Toys
  • 124 Answers
You have to give a bit more info is it the one with small electric motor on it most 1z made for kids only have 1 small motor on its wheel to run it but again need more info
Posted on Jun 29, 2014
Front wheel is stuck on
what are you trying to remove the wheel ? if you are . put one lug back on loose and hit the rim fron behind with a hammer
Nov 11, 2012 | Cars & Trucks
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Stuck in 4wheel drive how can I get it back to 2 wheel?
Try tapping the encoder motor with a hammer while a helper pushes the 2 high button. The encoder motor is the part on the transfer case that switches through the different drive options.
Jul 29, 2012 | 2005 Chevrolet Suburban
Stuck in 4 Wheel Drive Gear 1989 Jeep Wrangler was stuck in sand. Shifted to 4 wheel drive and now cannot switch back to AWD. Any suggestions?
Assume that is stuck in 4wd, cannot shift back to 2wd. Have you tried shifting to 4wd/Lo and back? Try letting out on the clutch while slowly rolling?
Assume you are manual transmission?
Jul 30, 2009 | 1988 Jeep Wrangler
2001 Suburban 4x4 will not connect
4x4 is not all wheel drive. You still have differentials that will only allow one wheel to direct power most of the time, unless you have posi diffs. Many times you can have one front and one back wheel spinning, even though you are in 4 wheel drive, but you should have had one front wheel spinning as well as the back one when you were stuck. Possibly the one on the other side of the truck was spinning.
May 26, 2009 | 2001 Chevrolet Suburban
2000 Chevy Four Wheel Drive Stuck in Lo
The electrical switch going to the 4wd is bad more than likely. It would be the one under the truck
May 26, 2009 | 2007 Dodge Dakota Cab SLT
My truck is stuck in 4 lo
pull atc 25 amp fuse in underhood fuse center and 10 amp 4wd fuse inside cars fuse box,your problem is in control box behind kick panel on pass. side ,corrosion build up,
Mar 06, 2009 | 2000 Chevrolet Blazer
Quinny zapp back wheels - help
Yeah the grey pin was stuck in. I noticed a small screw at the back of the hub which when removed releases a spring loaded black plug. Be careful when you undo the screw, otherwise you might lose the spring and the plug as they can fly out suddenly. Once you have got the black plug and spring removed you can stick a screwdriver in and pop out the grey pin on the opposite side of the hub. I then re-assembled the spring and black pin and job done the wheel didn't fall off again.
Jan 18, 2008 | Quinny ZAPP Stroller
Toys Logo
93 people viewed this question
Top 12Volt Toys Experts
Andrew Taylor
Andrew Taylor
Are you a 12Volt Toy Expert? Answer questions, earn points and help others
