Question about Skque CELL PHONETravel Wall Charger FOR LG WINE UX280 UX-280
Is there a sim card in the lg ux280. - Skque CELL PHONETravel Wall Charger FOR LG WINE UX280 UX-280
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
LG OPTIMUS BIG Can i put micro sim card in SD card slot on my lg optimus big?? Theres no sim slot!! I dont know what to do..
Your SD slot is for a memory card and putting a sim card into it will not solve anything. Call your mobile carrier and check with them regarding the sim card. Maybe your phone doesn't take a sim card. Go to LG.com and in the search area list LG Optimus user's manual and that should answer your questions. I looked on that web site for my LG user's manual, found it and downloaded it I WOULD LIKE TO MENTION TO THOSE OF US THAT CANNOT FIND A MICRO SIM CARD FOR OUR PHONES UNLESS YOU WANT TO PAY +$70.00 ON AMAZON. TAKE YOUR REGULAR SIZED SIM CARD TO A LOCAL CELL PHONE STORE AND ASK THEM IF THEY HAVE A SIM CARD CUTTER. IF THEY DO, THEY WILL PROBABLY CUT YOUR SIM TO A MICRO OR NANO SIM FOR FREE. IT WORKED FOR ME.
Apr 01, 2013 | Cell Phones
Cell phone contacts
Step 1Remove the SIM card from your Motorola phone. The SIM card is a small chip that is located under the battery in your cell phone. After you've removed the SIM card from your Motorola phone, remove the SIM card from your LG phone.
Step 2Insert the SIM card from your LG phone into your Motorola phone. Turn on the Motorola phone.
Step 3Press the "Menu" key and select the "Address Book" option.
Step 4Select "Options" by pressing the right soft key. The "Select Multiple to" option will appear on the screen. Choose the "Select Multiple To" option and then select "Copy to SIM to Phone."
Step 5Remove the SIM card that you placed in your Motorola phone and insert it in your LG phone. After inserting the SIM card, turn on your LG phone.
Step 6Click the "Menu" key on your LG phone and select the "Address Book" option.
Step 7Select "Options" and choose the "SIM Management" option.
Step 8Select the "Copy from SIM" option and choose "Select All."
Step 9Select the "Copy" option. Your contacts will be transferred from your SIM card to your LG phone.
Feb 24, 2012 | LG Cell Phones
Lg ux280
It can't be reset, only call time meters can be reset (outgoing and incoming)
Jan 31, 2012 | LG Cell Phones
How can I connect an LG Wine to my computer to change ringtones, update contacts etc. I used to have a motorola and the phone tools was awesome is there something like that for LG?
The data cable does nothing but charge the phone. If you have a bluetooth enabled computer, you can move data. This is from the LG message boards.
May 07, 2009 | Computers & Internet
Cell phone sim card
All mobiles have a sim card and are normally located under the battery.
Take the back of your phone, remove the battery and it should be there. Sim cards are normally a small oblong piece of plastic with a corner cut off. The flip side of one will have a metal strip, which is your sim memory. Don't damamge this side of the sim otherwise your card will be useless.
Hope this helps?
Dec 29, 2007 | LG VX8300 Cellular Phone
Forgot unlock code
During the 'phone code' press the upper middle button that acts as menu [not the one in between the directional buttons}, when It's done the phone will ack for security code, then press 00000 or 12345. it only unlocks the phone if you have not change your security code.
Nov 01, 2007 | Motorola Mobility RAZR V3
Skque CELL PHONETravel Wall Charger FOR LG WINE UX280 UX-280 Logo
19 people viewed this question
Top Skque Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Skque Cell Phone Expert? Answer questions, earn points and help others
