Question about Crane Humidifiers
Lights on but didnt work
Light is on no fumes
3 year old Essick tower D46720 sat during off season. Cleaned, filled and plugged in today and will not turn on. Lights are on; nothing happens.
The red water level light was on even though both tanks were full. The white float behind the filter WAS stuck to the bottom of the tank. I just moved it to its floating position and voila! it is working.
Nov 21, 2016 | Essick Air D46720 6 Gallon Humidifier
No water
well these dont work in winter 1st off if heater is on were u from try to wigle the water buket on it just right so sits in and turns on sum sensor toucjy the way they sit in
Jan 19, 2008 | Honeywell HCM-300T Humidifier
My diffuser will not mist. The lights are on and it is running fine otherwise. What is the problem?
Did you use distilled water ?
Ours called for distilled water to work correctly, we used tap water and it worked for the first few times. then started making noise and then stopped.
Started using RO water, (like distilled) and started working again.
Apr 07, 2015 | Humidifiers
Lights on but no fan, no mist
"Take the humidistat out of the humidifier and look for the 3 slits below the restart button, take a hair dryer and send some warm air into those slits for 5 minutes. That usually recalibrates the humidifier."
Feb 06, 2014 | Honeywell QuietCare HCM-6009 Humidifier
Replaced the Filter Now water leaks from the bottom
sounds like u didnt get ur drain in the hole right or u didnt get the filtr in correctly take it back out and be gentle and put it back together and should fix the problem
Feb 25, 2010 | Honeywell HE365 Humidifier
Humidifier control: red light is on. getting 24
the red light is lit because either you didnt install the manual mode resistor or your not using a out door thermostat but you have to hook somthing to the two terminals just to the right of the HH terminals
Dec 23, 2009 | Aprilaire 600 Humidifier
Where do i put the vicks in a vicks humidifier
you have to open the lid to the scent pad heater tray. the vicks pads go inside of there. now if you touch them with your hands you need to immediately wash hands after. cause of the fumes will be very strong. then close unit and turn on and it should work properly
Apr 16, 2009 | Vicks V4500 1 Gallon Humidifier
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
Humidifiers Logo
220 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
solver2010
Tom Chichester
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
