Question about Corel WordPerfect Office 11 (corwposlr) for PC
Font won't unbold
Font in my document is stuck on bold. I select and unbold but it won't work
    Scholar:
  • 51 Answers
Is this for a TTF True Type Font or some other font format?
Assuming you're running Windows, it all depends on which operating system you're running. Typically PCs use True Type Fonts (TTF files), which are installed and stored in the Fonts folder, which is a sub-folder of the Windows folder.
Some True Type Fonts are only available in Bold, Italic, Normal and Bold Italic. Some are also available in more or less variations. Some fonts are only available in Bold, some only in Italic, etc.
You may need to check if you have the Normal font installed, and it may be the font selected is only installed in the bold version. Another possibility is your Normal font file might be damaged or corrupted to where it's no longer recognized by your system.
You can check out the Fonts folder to see if the typeface you're trying to use is installed properly in the Normal style.
If not, select another font and see if that works for you. This would be a good indication that it's simply a matter of the Normal font variation not being installed properly.
Hope this helps!
Posted on Jun 14, 2014
Tip
How to change fonts in Windows Notepad
Windows Notepad is a fairly basic text editor. It doesn't offer a lot in the way of extra features, but one thing it does have is the ability to use different fonts.<br /><br />By default, Notepad uses the Lucida Console font. However, you can change both the font and the text size, as well as use bold and italic styles. The only drawback is that the whole document must use the same settings, so if you change the font, it will apply to all of the text; you can't have only one word appear in bold, for example.<br /><br />To change the font in Notepad, open an existing text file or create a new one by clicking on the Notepad link on the Start menu (Start &gt; All Programs &gt; Accessories &gt; Notepad). On the menu bar, click Format, and from the drop down menu, select Font.<br /><br />On the left side of the Font window is a list of all of the fonts you can choose from. To see what a font will look like, click on it. The text in the sample box will change to reflect that font, giving you an idea of what the capital and lowercase letters will look like.<br /><br />You can also change the text style by selecting Italic, Bold, or Bold Italic. (Unfortunately, you can't underline in Notepad.) The text size can be changed by selecting a number from the list under the Size heading, or you can type in a value in the field above the list. To change the script (in order to use the lettering or symbols of another language) select one of the scripts from the Script list at the bottom of the window.<br /><br />Once you've made your selections, click OK to apply them. If you just want to exit out of the Font window without making changes, click Cancel.
on Mar 30, 2011 | Computers & Internet
Fix font size
Bold underlined itallics fontsizes and colours
Type <b> before the writing that you want bold.
End the bold text, type </b> after the part that you want in bold to go back to normal.
Type <i> or <u>, to write in italics, or underline.
Type <center> to center a selected area. When finished, you will need to type</center>
Type <font color="colorcode"> and end it with </font>,to write with different colored fonts.
Type <font fontsize="size">to change the size of the font you would like to use.
hope this helps
Aug 27, 2012 | Dell Computers & Internet
How do i bold print
hope this helps
Aug 13, 2012 | Microsoft Windows Vista Home Premium with...
I am taking twelve, one page documents and converting them to a unified 12 page document. I have done this several times & everything works perfectly. This year, however, when I select the pages to...
I do not know what program you are using but it sounds like you may have a default paragraph or character style set up in the target document. For example if the document that you are copying from has a normal style that has bold setting and then you copy it into the target document that has a normal style with say italics, the normal style in the target document will apply.
This is the case in programs like quarkxpress and indesign. Hope this gives you some ideas to help you out.
Dec 09, 2010 | Computers & Internet
I want short cuts in ms word
You can use this
Ctrl + A Select all contents of the page. Ctrl + B Bold highlighted selection. Ctrl + C Copy selected text. Ctrl + E Aligns the line or selected text to the center of the screen. Ctrl + F Open find box. Ctrl + I Italic highlighted selection. Ctrl + J Aligns the selected text or line to justify the screen. Ctrl + K Insert link. Ctrl + L Aligns the line or selected text to the left of the screen.
Ctrl + M Indent the paragraph. Ctrl + P Open the print window. Ctrl + R Aligns the line or selected text to the right of the screen. Ctrl + T Create a hanging indent. Ctrl + U Underline highlighted selection. Ctrl + V Paste. Ctrl + X Cut selected text. Ctrl + Y Redo the last action performed. Ctrl + Z Undo last action. Ctrl + Shift + F Change the font. Ctrl + Shift + > Increase selected font +1pts up to 12pt and then increases font +2pts. Ctrl + ] Increase selected font +1pts. Ctrl + Shift + < Decrease selected font -1pts if 12pt or lower, if above 12 decreases font by +2pt. Ctrl + [ Decrease selected font -1pts. Ctrl + Shift + * View or hide non printing characters. Ctrl + Moves one word to the left. Ctrl + Moves one word to the right. Ctrl + Moves to the beginning of the line or paragraph. Ctrl + Moves to the end of the paragraph. Ctrl + Del Deletes word to right of cursor. Ctrl + Backspace Deletes word to left of cursor. Ctrl + End Moves the cursor to the end of the document. Ctrl + Home Moves the cursor to the beginning of the document. Ctrl + Spacebar Reset highlighted text to the default font. Ctrl + 1 Single-space lines. Ctrl + 2 Double-space lines. Ctrl + 5 1.5-line spacing. Ctrl + Alt + 1 Changes text to heading 1. Ctrl + Alt + 2 Changes text to heading 2. Ctrl + Alt + 3 Changes text to heading 3. Ctrl + F1 Open the Task Pane. F1 Open Help. Alt + Ctrl + F2 Open new document. Ctrl + F2 Display the print preview. Shift + F3 Change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word. Shift + Insert Paste. F4 Repeat the last action performed (Word 2000+) F5 Open the find, replace, and go to window in Microsoft Word. Ctrl + Shift + F6 Opens to another open Microsoft Word document. F7 Spell and grammar check selected text and/or document. Shift + F7 Runs a Thesaurus check on the word highlighted. F12 Save as. Shift + F12 Save. Ctrl + Shift + F12 Prints the document. Alt + Shift + D Insert the current date. Alt + Shift + T Insert the current time.
Oct 11, 2010 | G7 Productivity Systems VersaCheck For MS...
Cant make prints lighter or darker
There are two ways to do this. One is to change settings in whatever application your are using. Increase your font size or bold your font (if you're talking about a document.)
The other way is to change your printer properties. Go to your printing preferences (from your print dialog or from Start->Printers and Faxes->right click on Lexmark 5400 Series->select Printing Preferences) and increase your Print Quality.
Steve
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
MS Office 2003 Problem with Bold
You could have done a number of things (by accident of course) so it’s hard to find - on line.
Therefore the best solution would be; to remove you Office installation and re install it.
Start -> Settings -> Control panel ->ad remove program, find and remove Microsoft office.
Restart the computer, and reinstall your office.
/Teis
If this was helpful, do remember to vote before you leave.
Thank you
Dec 11, 2008 | Microsoft Office Outlook 2003 for PC
Font misbehavior
Melissa, try saving your Microsoft Word document as a standard ASCII text only document (File > Save As), then use that new non-Word document to copy and paste. This avoids all the strange text formatting and problem codes from Word. Format your text in Dreamweaver and perhaps try using Cascading Style Sheets (CSS) for formatting your pages.
Best of luck!
Jun 09, 2008 | Macromedia Dreamweaver MX 2004
Increase font size on Nokia E65 Mobile Phone
NOKIA SAYS THAT THE FONTS ARE NOT CHANGAABLE THEY ARE WRONG!
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf
The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
Oct 18, 2007 | Cell Phones
Corel WordPerfect Office 11 (corwposlr) for PC Logo
154 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
