Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Blowing fuse when tractor running YTH24K48
I have a 2008 to 2009 YTH24K48 it is blowing the fuse while running as soon as the engine hits operating rpm. After the fuse blows the engine continues to run and the PTO engages and disengages fine but when I shut it off it will not start again until a new thin gauge jumper is in place of the fuse.
5 Suggested Answers
  • 21 Answers
SOURCE: blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Posted on Jul 27, 2009
mickey813
  • 472 Answers
SOURCE: GTH2548 drive spring broke and I replaced it.
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Posted on Sep 08, 2010
heatman101
  • 43501 Answers
SOURCE: Starting my husky 2540 riding
Check all of the wiring to the switch and the PTO clutch. You may have a wire that is either rubbing on the frame and shorting out or the two wires are rubbing together and shorting out...you have stated that you have checked the wires, but make sure to untape everything and check all parts of the wiring...
If all of the wiring looks to be in good shape and there are no scraps or scuffs, then the PTO Clutch is going bad and the magnetic clutch is either shorting or pulling too much current to engage it.... it will need to be replaced... not an easy project most of the time.
These clutches often do fail, and because of the heat of the engine and such they are usually very hard to remove. Make sure to have a good puller before you even think of trying to get it off of the shaft.
Bottom line is that it seems as though the problem is probably the electric clutch...
heatman101
Posted on Aug 29, 2011
  • 6468 Answers
SOURCE: pto, electric clutch
check the wires they rub on sharp edges
Posted on Mar 24, 2012
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
Would the electric clutch for the mowing deck on a wizard riding mower with a Kohler 20 hp engine cause it to act like you hit a kill switch. If it went bad ?
Not normally. Most times they short out blowing the fuse.
It sounds like the engine running fine until engage the clutch. It more likely that you have a safety switch related problem like a bad seat switch or loose connector..
Aug 31, 2014 | Garden
Why does my john deere 5075e keep blowing ignition fuse
It has to have a short either at the starter or the ign. switch just check the wires that carry power and make sure none are earthing out.
Aug 17, 2014 | Garden
My YTH24K48 is blowing the 20 amp fuse,
Have you or can you gain access to a wiring schematic/diagram of the machine and specifically the fuse your referring to and all of the components it powers? If you can I'm quite sure I can help you. Sometimes the dealer/employees will photo copy the pages you need and more so if you offer to pay them or tip them for what you need. Get back to us.
Nov 19, 2013 | Husqvarna Garden
My 02' mdx won't come out of park, keep blowing a 20 amp fuse. This fuse controls the Cruise, break lights, memory seat, horn and linkage. I have to manually delink. I have unhooked the comand...
Here is an idea, when do you blow the fuse key on, key on engine running, key on engine running hitting the break pedal? Try and get the key on without blowing fuse if possible, then one at a time try those circuit loads ie: horn, brake pedal and so on, if you isolate which load is pulling to many amps(blowing fuse) unplug that load itself, then restart testing, see if fuse stays ok. You can also substitue the fuse with a circuit breaker and unplug each load until click(of breaker) stops.
May 17, 2011 | 2003 Acura MDX
THE MICROWAVE KEEPS BLOWING FUSES, AS SOON AS I HIT THE START BUTTON THE FUSE BLOWS.iT WILL KEEP THE TIME AND THE LIGHT WILL COME ON BUT AS SOON AS i HIT START IT BLOWS
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Kenmore 63792 Microwave Oven
Tractor keeps blowing a fuse
Check for a wire that has a bare spot on it rubbing the body of this mower. The vibration the engine makes shakes the wiring so it must have a bare spot somewhere under the seat or towards the engine
May 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna yth2348 keeps blowing fuses as soon as one is changed and you attempt to turn it over the fuse blows
You have a dead short in the circuit for that fuse. Check for a pinched wire, or a wire rubbed thru a touching metal.
Sep 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cub Cadet zero turn:Engine starts and runs about 5 seconds before blowing 20 amp fuse.
You may have a faulty voltage regualtor that is blowing fuse. Have you tried a fuse that is 5 more amps?
Aug 24, 2009 | Mtd Gold 42" Zero-Turn Mower -
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
53 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
