Highlander XQG70-DA112PE error code 05 - Televison & Video
How can I loosen actuator lever stuck on cool?
try this hope it helps
http://www.sparkys-answers.com/2009/05/2003-toyota-highlander-ac-stuck-on-heat-2.html
Feb 13, 2016 | 2004 Toyota Highlander
The erore E33 little swan front loading w/ machine
I suggest that you search online for "error code e33 + little swan" you'll find most websites will offer some information.
Jul 11, 2015 | Washing Machines
Rank arena washer dryer
hello how do i get the dryer to work on the
  • Brand Name: Rank Arena
  • Model: XQG70-DA112PE
Jul 18, 2013 | Televison & Video
How do I get the air out of the cooling system in my 05 v-6 toyota highlander
run engine with rad cap off till up to temp.add coolant as needed replace cap before turning engine off.
Feb 14, 2011 | 2005 Toyota Highlander
2005 Highlander: I don't think four wheel drive is working. How can I determine? Is there a switch for four wheel drive, as someone suggested?
Are you sure your vehicle is a 4 wheel drive version? Double check your model information to make sure. If it is, technically, it is all wheel drive - meaning the other wheels engage automatically when the vehicle detects that they are needed. I have an 05 Highlander AWD, too. Good choice. I love mine! Good luck.
Oct 12, 2010 | 2005 Toyota Highlander
Can i use dex cool as a replacement coolant for my 2004 highlander? will it hurt anything?
you should be running g-05 long life antifreeze in a highlander. You can pick it up at any auto store.
Mar 20, 2010 | 2004 Toyota Highlander
How can i check for error codes?
There is no built in way of checking codes without the use of a scantool.
There are several low priced but very basic scanners available at auto parts stores, ranging from $25-75 for basic scanning..
Many auto parts stores will scan your codes for you free of charge (in hopes of selling parts).
AutoZone, Advance Auto Parts, and O'Reilly are 3 stores that offer free check engine light scanning.
Oct 22, 2009 | 2003 Toyota Highlander
Maitance light stays on
It is in the manual. Hold trip button in and turn key to on pos. Hold the button til the blinking dashes disappear. done
Jun 30, 2009 | 2005 Toyota Highlander
Antenna 05 highlander
You have to pull the radio out of the dash, the antenna socket is on the back of the radio. You cannot see or get to the back of the radio whilst it is still bolted to the instrument panel.
Oct 12, 2008 | 2005 Toyota Highlander
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
