Question about Cuisinart CBT-500 SmartPower Premier Work Top Blender
Blender is on but buttons do not start the motor
Power to the unit is on . the motor does not resond when low or high buttons are pressed
Does the blender have a reset button for the motor
Not for the motor - perhaps for circuit breaker. If you overheated the motor by blending a liquid with excessive viscosity you may have burned out the unit. Or maybe the motor overheated and a protective thermistor has shut off power to allow it to cool off. Give it another hour or so before making any conclusions.
Aug 23, 2017 | Blenders
I have an ICB 3. The LED display lights up and when you touch the buttons it beeps but, it will not spin.
I called blendtec and got it figured out. The unit was in some locked mode and so I had to push the buttons 4-1-3 in that order to get it to work. The confusing thing is there's two invisible buttons between 1,2 and low, high. So the buttons go 1, 2, 3(invisible), 4(invisible), 5 (low), 6 (high). It mentions these options in the manual on page 18.
Jun 25, 2011 | Blendtec ABC Work Top Blender
Blender died ...... motor won't turn on
Have you tried the fuse first....
If it is the motor (quite rare), these people may be able to order you one:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Aug 10, 2009 | KitchenAid KSB3 Classic Work Top Blender
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Wont turn on. its plugged in and the switch on the plug socket is turned on
have you fix the container? most blender today has a switch to verify if the blender container is fixed to the motor.
May 31, 2009 | Blenders
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
Mar 17, 2009 | Back to Basics Smoothie Jr. B Work Top...
I have a Kitchenaid blender model KSB5BU3 marked "Ultrapower" and "Electronic Control" on the side. Suddenly all the buttons started blinking together after we pressed the On button and then one of the...
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Jan 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Will not work
First ensure that the blender jar is placed on the right orientation, othherwise the blender wont start.
Remove the Jar and place it on the other way if you are not sure.
If you still get the click, try leaving the blender power cord unplugged for a while. The click means that the blender has power, but the motor is not starting.
If it still does not work , and the jar is in the correct way and you did the above, then the blender is faulty, probably a faulty motor, or a broken wiring.
Dec 19, 2008 | Krups 574 Power Xtreme VI Premium Work Top...
Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Mar 24, 2008 | Westinghouse WST2000 IntelliBLEND Work Top...
Cuisinart CBT-500 SmartPower Premier Work Top Blender Logo
42 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
