SOURCE: Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
SOURCE: kenmore ultra wash II model no. 1691190
YOUR MAN WAS OF ABSOLUTLY NO HELP IN SOLVING MY PROBLEM. I ENDED UP CALLING SEARS AND THEY SENT A TECH OUT. YOUR MAN SAID TO TAKE THE DISHWASHER OUT AND TURN IN ON IT'S BACK AND I COULD ACCESS THE PUMP. THE TECH SAID THIS WAS NOT TRUE. YOU CAN ACCESS THE PUMP FROM THE INSIDE OF THE DISHWASHER. IT IS APPARENT TO ME THAT YOUR TECH HAD NO IDEA ABOUT THE MACHINE. AS IT TURNED OUT, THERE WAS NOTHING WRONG WITH THE DISHWASHER. IT HAD A KINK IN THE DISCHARGE HOSE.....P
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
You
use your dishwasher so often with no problems that any issue can seem
like a major disaster. But you can fix a drainage problem with a trip
to the hardware or plumbing supply store and a few minutes of effort.
If your dishwasher doesn't drain properly, the drain hose is probably
kinked or damaged, interfering with the flow of water out of the
dishwasher. You can fix the problem by replacing the drain hose
yourself.
Difficulty: Moderately Easy
Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
