Question about Osmo Essence Ikon Permanent Hair Colour - 0.00 Blonde Boost
How many gms of osmo ikon blonde boost should i add to osmo ikon 12.19 to get hair white,silver blonde
Bleached hair roots turned white the rest is orange
You cannot lighten "color" with "color". If you had to, and only had one color, you could possibly put color on the ends first, wait 10 mins and then apply to roots (which is difficult to do on your own hair) Virgin (uncolored hair) lightens MUCH faster than colored hair. alot of times the colored parts of the hair will never get as light as the roots, without using a differant product. This is why people go to salons :) Anyway, first try Matrix shampoo called "So Silver" (this will tone the hair. Its purple color neutralizes the orange. Most likely though, the color you used was a darker level of color than what your ends were and since you cannot lighten color with color, you get brassy orange. Go to sally's beauty supply, pick up some hair bleach, 20 vol. developer. mix together equal parts. wet your hair, lather with shampoo/conditioner mixture, and smush bleach mixture ONLY to your orange ends (NOT YOUR ROOTS)watch your strands fade from orange to light pale blonde and rinse as soon as it hits desired level (only takes a few minutes) Hope this helps.
Sep 02, 2014 | Clairol Nice n Easy Born Blonde Hair...
My sideburns are turning white but unevenly. I want them white. How?
Three solutions to this: you can dye them to match either bleaching the darker side till it's lightest blonde and adding a grey toner (hard to match and quite damaging, use a tone colorant which is a few shades lighter to color the white hair only (looks natural If done properly) while your hair is in that stage. Or shave your head.
Aug 25, 2013 | Health & Beauty
Can I use 30 vol with matrix vlight bleach?
yes you could and tone with a violet base level 9 i did it and went fine if she wnt lighter you could add foil ???
Apr 22, 2012 | Cars & Trucks
Can I put Loreal Feria 93 on bleached hair which was done over a month ago and achieve the color on the box?
Golden blonde is safe for high lift blonde hair, if the bleached hair is lighter than the color on the box it should match normally.If the bleached hair is not as light as the box it can lighten it some and help at tones to your hair.
Jun 02, 2011 | L`Oreal Feria 93 Candle Glow Light Golden...
How much peroxide do i add to koleston perfect 8/00 to put blonde hi lights in red hair
Its equal parts, Make sure you use 40 vol peroxide and you have virgin hair ( No Other Color )
You can't lift color with color you would have to use bleach if you have color on your hair and it hasn't been cut out all the way!
Nov 26, 2010 | Wahl Health & Beauty
Can I dye my hair blonde for a day?
Not exactly... the term "dye" causes a lot of confusion, but dye generally means making the hair darker. To make the hair lighter you must use a special bleach. Hair bleaching is permanent and cannot be rinsed away. It can be dyed back to it's original color however, but the bleach does damage to the hair. In extreme cases, where the hair was dark brown or black and is bleached to blonde, the hair becomes very thin and resembles the texture of cotton. You can lighten hair temporarily by using theatrical hairsprays. These come in every color of the rainbow including white, gray and blonde. These color sprays actually sit on the outside of the hair strand, and can be shampooed completely out after brushing the hair.
Nov 23, 2010 | Health & Beauty
Osmo Essence Ikon Permanent Hair Colour - 0.00 Blonde Boost Logo
94 people viewed this question
Top Osmo Essence Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Osmo Essence Health and Beauty Expert? Answer questions, earn points and help others
