Honeywell chronotherm iii died
I went to change my thermostats batteries and while it was working fine when it was hooked up, it died completely when I took it of its base. Even with new batteries.
  • 69 Answers
Did you check for correct positioning of new batteries ? also when but back on base is it securely attached?
Posted on Nov 19, 2013
4 Suggested Answers
  • 10 Answers
SOURCE: -AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Posted on Dec 12, 2008
  • 233 Answers
SOURCE: I have a honeywell III chronotherm thermostat /It
it sounds like it is time to repalce the stat, auto is set to allow the fan to run only when the heat or a/c is on, the switch for heat and cool will select either, and the temperature lever should allow contact for the bulbs to bring on the desired component. there are no replaceable parts on a thermostat, or I would try to walk you through replaceing them. good luck.. I prefer the honeywell vision pro or the white rodgers 9500 series stats
Posted on Jul 14, 2009
  • 308 Answers
SOURCE: my honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Posted on Jan 23, 2010
How do I replace the battery in my Honeywell chronotherm III thermostat?
Pull the face plate evenly all the way around, it just snaps off the back plate screwed to the wall batteries are visible .
Dec 21, 2017 | Honeywell Computers & Internet
My honeywell chronotherm III says -AC any ideas
Jan 22, 2010 | Heating & Cooling
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
