Keyboard will not work
It works when I log on under guest but not on my name
    President:
  • 623 Answers
That doesn't make sense...unless the keyboard is disabled in your profile. If you are using Windows, check the Device Manager and see if that's the case. Can you log on as local administrator?
Posted on Nov 19, 2013
I live Honolulu Hawaii. When wifi connects a page comes up...Guest Access Belkin login. What is the password?
Obviously I shouldn't know the password. But it looks like the WiFi access point you're trying to connect has a external login page configured. Which require a user name & password. Although some system has free browsing option for guest. You should contact the administrator for your username & password.
Thank you
Feb 03, 2015 | Belkin Computers & Internet
I can't log in to my account on my Dell PC?
What program are you running, Is it windows 7 or windows explorer.
Apr 10, 2013 | Dell Computers & Internet
Bike Race. App on Android. Zte n762. Keeps logging me in to 'guest' when i want to sign in with facebook
if u look under all ur multiplayer games, ull see itll say ur name with (guest) next to it, now try ur login to facebook button and then after u go through it look back down at ur little black text under the games and if it has worked it will have changed to (facebook) instead of (guest)
Dec 23, 2012 | Video Game Consoles & Games
How to get computer off a tempory profile
which operating system ?
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
My hp pavilion g series is loged on to a tempery profile so every time i log off everything is erased
•Guests
•Domain Guests
1. Click Start
or
hope this helps
or
hope this helps
How do I get a guest passord off and mine on Facebook
Logout of faceback if it is logged in. Look for the Logout in the upper right hand corner under where it says ACCOUNT. Then login with your name and put in your password and remember me if you want it to connect to your account name the next time you go on facebook.
Jul 29, 2011 | Dell Inspiron 2200 Notebook
Cannot log in hdd user requested password where did this come from and how to bypass?
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
or if you still cant get past this password
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
or
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
hope it helps.
don
Feb 20, 2011 | Acer Computers & Internet
My physical keyboard is unresponsive windows xp
Go to THIS website and download the keyboard/mouse driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-40564-2&lc=en&dlc=en&cc=us&os=228&product=403789&sw_lang=&key=null&site=null
problem solved.
Make sure your logged on in a computer administrator account(not limited access like guest account), and then make sure all other accounts are logged off. If it worked it will ask to restart the computer. When the computer reboots the keyboard etc should work.
Jan 07, 2011 | HP Presario SR1020nx (DW255A#ABA) PC...
Same Problem
May be you had type the wrong user name or password...or your email adress is not working. . .you may use your security question to open your account.
Jul 30, 2009 | Facebook Social Network
System won't go past profile page..stuck
It seems that the Guest account profile is corrupted because of which you are unable to log in as like in previously.
In the Profile Login page, hold the Ctrl and Alt keys and press the Del key twice.
This will give you a window where you need to enter the User name and Password.
Enter the User name as administrator and leave the password column blank if you have not set any Password to the administrator account or enter the Administrator password if you have set any.
Now once you are loged into the Administrator account, create a new User from the Control Panel > User Accounts.
Set the required limitatios to the account like limited account or administrator account and log off from the administrator account.
Now, you should have the newly created user account available in the login page. Select it and you should be able to login.
Aug 11, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
