Question about HP Photosmart C7280 All-in-One Printer
Unknown device on HP Photosmart c7280
After power outage and reconnecting to a different surge I turn on printer and it displays Unknown Device. will print but not scan, fax, or copy
tom19511
  • 1601 Answers
SOURCE: SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Posted on Nov 01, 2007
SOURCE: Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Posted on Feb 20, 2008
mspcrepair
  • 169 Answers
SOURCE: 1) can not scan to
Assuming you're using Windows XP, you either need to install the full software suite (to access copy, scan, fax and print features), or if you don't have the CD, download the package here:
ftp://ftp.hp.com/pub/softlib/software9/COL19845/mp-52268-4/100_228_PS_AIO_02_Full_Net_enu.exe
Let me know if this helps, and please remember to rate my answer :)
Posted on Sep 29, 2008
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
SOURCE: HP02 Ink (Expired)
I HP made cars they wouldn't start until you change your dirty motor oil.
Posted on May 23, 2010
Printer won't turn off
Check the power supply cords; make sure they are attached properly. If you are using a power strip, surge protector or any other device where the power supply cord is not plugged directly into a wall outlet, bypass them and plug the printer into a wall outlet; see if that changes anything.
If that doesn't work, remove the printer's power cord from the outlet and all the other cables that the printer connects to the computer to.
Wait 5 or 10 minutes for the printer's CMOS and RAM chips to power off completely.
After enough time has elapsed, plug only the printer's power cord into the wall outlet (do not hook up any of the communication cables in e.g. USB, or serial cables, or network cables.)
Then press the power "on" button.
If the error message is gone, power off the printer.
Uninstall the printer and all its programs from the computer.
Do a clean install and follow the procedures of hooking up the printer as though you are installing it for the very 1st time.
You may have to obtain firmware and/or software updates from HP on your specific printer.
You may also have to check with your OS vendor to make sure you have all the updates/service packs on your PC or laptop
Nov 23, 2013 | HP Photosmart C7280 Printer
Oxc18a0206 hp photosmart c7280
Unplug power cord from printer and electrical outlet wait 30 seconds and hold in help and OK buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 13, 2013 | HP Photosmart C7280 Printer
I have an HP Photosmart C7280. The printer will not turn on. Every time I try a blue screen comes up on the display and then all of the lights start flashing.
1. unplugged the power cord for 20 seconds (actually went a little longer)
2. Held down the # and 6 keys together and then plugged the power cord back in (still holding the keys).
3. held down # and 6 for about 10 more seconds after plugging the power cord back in and didn't get any messages but once and release them It was able to turn the power on.
The printer then printed an alignment page
hope it works, if so do rate the solution
Nov 28, 2010 | HP Photosmart C7280 Laser Printer
Printer plugged in but no response when power button pushed. Could power supply be dead?
The power supply could certainly go bad. Have you had any power surges or outages recently? Do you use a surge protector? Is there any other device plugged into the same circuit that is having problems?
You can probably find a new power supply for your printer somewhere online, but between the cost to buy it, cost to ship it, and time spent replacing it, you're probably just better off buying a new printer.
May 27, 2010 | HP Photosmart C4180 All-In-One InkJet...
Printer will not turn off.
UNPLUG THE POWER CORD FROM THE BACK OF THE PRINTER LET IT SIT FOR 2 MINS UNPLUGGED THEN RECONNECT THE POWER CORD AND TURN THE PRINTER BACK ON. THAT SHOULD REFRESH THE PRINTER
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
Won't turn on
I had a like problem with a HP printer after I returned from vacation. While mine wound up being dead from a power outage while I was away, make sure the power supplly is firmly connected, also try another outlet, as silly as it sounds. but most likely the power supply failed. You can look for a replacement on a popular auction site and expect to pay up to 10 bucks for a OEM unit.
Jan 30, 2010 | HP Photosmart C7280 Printer
Using the HP C7280, lost power and now its asking me to input a WEP #. Where do i get this number?
Check with your network administrator or the person who installed the Photosmart C7280 on your network.
A WEP key (in short) is a security code allowing a group of devices to communicate with each other while maintaining privacy from a device outside of the network. Usually a WEP is a string of digits and the letters A-F the length of which is determined by the level of encryption.
Jan 03, 2010 | HP Photosmart C7280 Laser Printer
Set language in german
Follow these steps to resolve the issue.
  1. Unplug the power cord from the back of the product.
  2. Press and hold the # and 6 buttons simultaneously on the control panel, and then reconnect the power cord.
  3. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
  4. If the product automatically turns off, turn it on.
  5. Allow the product to fully start up, and then select the correct language code and country/region when prompted.
Jul 17, 2009 | HP Photosmart C7280 Laser Printer
Printing photos on C7280 printer directly from camera
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE.
rate this solution as fixya if this helps u to encourage us to solve more and more problems like yours.
Jun 14, 2008 | HP Photosmart C7280 Printer
HP Photosmart C7280 All-in-One Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
