Question about eMachines T5274 Desktop PC
Turn onboard video card - eMachines T5274 Desktop PC
  • 48 Answers
Dear,
There are two type of setting first from BIOS where you can go under peripherals option and set on board vga as a priority vga and other is
some board have jumber for switch over on board vga and agp pci express card.
most of pcs have setting from bios
best
Posted on Nov 19, 2013
No video and it doesn't have video card how to fix no video on monitor
if the onboard video is dead you can either try a video card and turn off onboard video other wise replace motherboard
Jul 23, 2015 | Computers & Internet
NO ONBOARD VIDEO
Hello here is the ASUS homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N73-AM&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Your pci-e graphic card is failing or has a defect.
The problem could also be the power supply, not giveing enough power.
When you add a pci-e graphic card on the mainboard, the onboard graphic should deactivate itselves.
Try to remove the pci-e graphic card, and use the onboard graphic.
If still no picture, change the power supply.
Its not possible to change settings in the bios blindfolded.
You can reset the bios by removeing the cmos battery.
But ofcouse it could also be the mainboard itselves failing.
This is rarely happening, so i hope its just the power supply.
Try also to look for visual defects on the mainboard, especially the condensators on the mainboard.
Good luck
Apr 14, 2013 | Computers & Internet
Can a PCI video card be installed on the Intel SE7501BR2 server board? My onboard video has color problems. I tried a known-working PCI video board after turning off onboard video, but got no video...
Most of the time you'll need to change a setting in the BIOS to force the computer to recognize the PCI slot first. Try going through your BIOS settings until you find it. It should be something like "Display First" or Primary, and it should be set to onboard graphics. Try changing that to PCI and see if that fixes your problem.
Aug 29, 2011 | Intel Server Board SE7501BR2 Motherboard
I install a video card nvidia fx 5500 agp in the computer ,set in auto for the onboard video,and when i restar the computer .the video card is not working .and the onboard card as well.when i remove the...
Enter BIOS and disable your onboard video card, shutdown PC, add your FX 5500 , Turn on PC....simple and easy. I hope this solution will be helpfull for you!
Apr 06, 2010 | Dell OptiPlex GX270 PC Desktop
My biostar g31 -m7 te motherboard does not boot when i try to add a msi rx800 pcie video card,,sometimes i get a overclock fail message after i remove the card and reboot,,,how do i get this card to work...
Turn the computer off.
Remove the PCI-E video-card.
Boot the computer.
Press DEL to "enter BIOS setup".
Disable the "onboard video" adapter,
or set the highest video-priority to be the PCI-E slot.
Save settings, but do not "exit" from BIOS setup.
Install the PCI-E video-card.
Disconnect the video-cable from the onboard VGA-port,
and connect the video-cable to the new video-card.
Turn the computer on, and the video-output through the new video-card should be displayed on your monitor.
Nov 05, 2009 | Biostar G31-M7 TE Motherboard
How do I reactivate my onboard video on my mobo ? (Asus A8V-MX-UAYKZ)
It will automatically be activated if you remove your Graphic Card
Sep 21, 2009 | ASUS K8V-MX Motherboard
Pc powers up but no video on screen gateway 420gr desktop
Yes generally speaking when you drop in a videocard it typically will disable the built on one. You may have to disable it though. I know you said you did not see the onboard video in BIOS but there is almost always a setting in there to turn it off.
Sep 17, 2009 | Dell Dimension 8200 PC Desktop
I want to use another video card
You can install anoth video card without turning th onboard video off, you will see the option to use the new video card in the windows display settings, if you do not hook a monitor up to the onboard video it will not use it either.
Mar 10, 2009 | ASUS P4P800-MX Motherboard
Video Card Upgrade Problems
Does this computer have an onboard video card?
If so you will need to disable this feature in the system BIOS.
It should be under onboard devices.
You will need to use the onboard card to enter the system bios and then turn off the onboard card. install the new card and then connect the monitor to it then power on the machine
Nov 30, 2008 | E-Machines eMachines Desktop PC
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
eMachines T5274 Desktop PC Logo
37 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
