Removing dvd drive - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 22,133 Answers
What is the laptop? There is usually one screw to the rear of the drive.
Posted on Nov 19, 2013
How do I replace my broken DVD RW drive?
Removal of the case will give you access to the drive mounting area. As a general procedure, disconnect the cables, remove the attaching hardware and remove the drive. Be sure to save the removed hardware for installation of the replacement drive
Apr 18, 2014 | Gateway FX6860-UR20P PT.GCEP2.001 Desktop...
Whenever i put a dvd/cd in my hp probook 4510s and try to open it, it insteads ejects
Remove the Power Cord, Remove the Battery, then close the lid and turn the laptop over and remove the one screw that holds the dvd drive in place on the bottom of the laptop. Remove the Dvd Drive and in about 20 seconds put it back in and Try rebooting to see if it solves the problem.
Your dvd drive might be defective and needs to be replaced. You can find one on ebay. Just put HP Probook 4510s DvD drive in the search.
Once you take the dvd drive out you can also search on the model of the dvd drive. The model will be listed on the dvd drive.
May 12, 2012 | HP ProBook 4510s Notebook
Does not recognize dvd drive
When you click Start/My Computer is the DvD drive shown as one of your devices? If not then try the steps below:
Remove the Power Cord, Remove the Battery, turn the laptop over and remove the one screw that secures the dvd drive and pull the drive out. After 20 seconds plug the DvD drive back in, and then try booting to see if it is recognized. If the drive is not recognized then you will have to remove upper and lower filters.
If you are talking about the drive won't play a dvd then that's another issue. Most times computers have a hard time playing something that was created by someone else. Try a store purchased DvD and see if it recognizes and plays it.
Apr 07, 2012 | Computers & Internet
How do I remove the DVD Drive on a Toshiba Satellite 1955-S805 laptop and where can I buy a new one
To remove the drive you will need to remove the small screw on the bottom of the laptop that holds the drive in place. Look for a CD symbol near a screw aproximatly 6 inches in from the DVD drive center. Remove that screw and the DVD should slide out. The best place to get a replacement drive is Ebay Do a search for the model and DVD and you should see many for sale
Feb 19, 2012 | Computers & Internet
I have a IBM thinkpad that has a cd drive only. Is there a way to take out the cd drive and install a drive that is for cd's and dvd's. If so, how would I go about doing that and how much would it cost?
Hi, what it the model of your DVD? Please the correct driver here : www-307.ibm.com/pc/support/site.wss/TPAD-MATRIX.html
Other tips : CD and DVD drive troubleshooting
  1. Verify the disc media used.
    Try multiple original discs (not burned copies) which are clean and free of scratches. See Information about CD and DVD media.
    Note: Dark colored discs such as black may be more difficult to read.
  2. Verify that the disc is seated properly in the CD-ROM, CD-RW, or DVD drive.
  3. Verify that the drive is seated properly in the ThinkPad system by reseating the drive.
    If another similar machine is available, then verify that the drive works in the other machine and that the other drive works in this machine.
    Notes:
    • The CD-ROM, CD-RW, or DVD drives cannot be removed in ThinkPad G40 and R50e systems.
    • Shut down, remove the power cord, and remove the battery from the ThinkPad system before removing the CD-ROM, CD-RW, or DVD drive.
Feb 09, 2011 | IBM ThinkPad DVD_ROM Ultrabay (73p3270)...
How do I remove the dvd or cg drives in my hp 8676c? I cannot get the drives out. I see the little lever but I still cannot get the drives to move Thanks. Jim
remove both side panels from your computer you should see 4 screws 2 ea side that are attached to the cd/dvd drives
hope this helps
Dec 05, 2010 | Toshiba SD-M1302 DVD Drive
I need to know how to remove a DVD drive for a HP lap top.
If your HP Pavilion DV6000 series laptop computer has a bad DVD drive, use the following steps to replace the drive
Purchase a new DVD drive to replace the old HP drive. You can use any slim DVD drive with a 50-pin ATAPI IDE Interface Connector. You will probably want a DVD burner since the original drive was capable of burning DVDs. The drive I used to replace the HP drive is a LG Black IDE Super-multi Slim Notebook DVD Rewriter - OEM version.
Unplug the power cord from your HP laptop. Remove the laptop battery from the back of the computer. This will eliminate the chance of power damage to your computer
Ground yourself by touching a metal object or touch your screwdriver on the ground while touching part of the metal. Unscrew the DVD drive screw circled in the Step 2 photo. Using a small Phillips head screwdriver turn the screw counter-clockwise until it is completely loosened. You may need to flip the computer over to get the screw to fall out. Put the screw in a safe location for later.
Put a small pointed tip object (a paper clip will also work) into the drive release hole on the face of the DVD drive. Use the hole to pull the drive out from the laptop body.
Remove the mounting bracket from the old DVD drive. There are two small Phillips head screws that need to be removed by turning them counterclockwise. Match the bracket up with the holes on the side opposite of the connection port. Using the two screws you just removed, secure the mounting bracket to the new DVD drive by tightening them in the clockwise direction.
Remove the original HP DVD drive face plate from the old drive. It can be removed by working it back and forth to loosen the faceplate. Once it is loose you should be able to pull the faceplate off.
Do the same for the new drive. Once the DVD faceplate is off, match the tabs of the original HP faceplate up and press in until it clicks into place
The new drive is now ready to install into the HP DV6000 series laptop. There is no need to hook up IDE cables and power cables. The new drive can simply be slid into the HP laptop.
Find the screw from Step 3. Make sure the DVD drive is pressed in all the way. Install the small Phillips head screw in the back of the laptop and tighten by turning clockwise.
Jun 19, 2010 | HP Pavilion dv6000z Notebook
I want to detach matshita dvd drive from lenovo 3000 y500..
Before you've remove the dvd rom try to check also the connector cable of the dvd rom. Try to use another cable if you have. maybe the defect is the cable. Just try to use another cable.
Regards
ICman
Dec 23, 2009 | Lenovo 3000 Y410 Notebook
Removing the DVD-ROM drive
hi the removel of the dvd drive is easy as taking out the battry 1. Remove the battery from the bottom of the laptop 2. Make sure the laptop is NOT plugged in. 3. There is a release button for the CD/DVD ROM drive on the bottom of the laptop, simply press and hold the release switch and pull the CD/DVD drive out. replace it with your new 1 good luck
Apr 06, 2006 | Toshiba Satellite Pro A10 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
