Question about Philips Magnavox 51MP392H Rear Projection Television
My tv stop working from running condition shows black screen even blue light is on
I have 43inch Philips rear projection. it give some sound and suddenly my tv stop working from running condition. tv shows blue tight on but screen is still black. no picture
  • 1153 Answers
SOURCE: Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Posted on Sep 05, 2007
  • 1694 Answers
SOURCE: Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Posted on Nov 26, 2007
ctf1800
  • 4402 Answers
SOURCE: philips rear projection tv 43pp8545 no picture sound ok
do you get a blinking read light?
Posted on Dec 14, 2007
  • 579 Answers
SOURCE: Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Jan 22, 2008
Ecollier2012
  • 3459 Answers
SOURCE: 9p6040 c102 philips magnavox rear projection tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 16, 2009
My philips 50" projection tv screen looks green or light blue
the picture tubes are liquid cooled,coolant is contaminated and mist be changed.any questions just give us a call 410-388-9399
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
Projection lights don't line up
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
I think I have the same tv. Its a philips 50 in projection tv.
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Jun 14, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television
Sounds like the blue convergence IC s bad. They are relatively easy to replace if you can solder they cost around 10.00 each and you should change both the red and the blue.
Feb 09, 2008 | Philips 50P8341 50" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
