Question about Philips Televison & Video
Philips flat tv 26PFL5322/10 bad sound quality
4 Suggested Answers
  • 70 Answers
SOURCE: Philips 30" Plasma Flat screen
if you are getting sound but no picture that good at least the set is not
going into protection mode. Which can make fault finding more
difficult.
What you should check is that the 12 volt supply from the power supply
to the signal board is present.
other then that check that you have the high voltages present if this is not
the case then you most probably have an issue with the x control board
or scavio as its known.
Posted on Nov 11, 2008
  • 105 Answers
SOURCE: Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Posted on May 21, 2009
  • 113 Answers
SOURCE: Poor sound quality on philips flat screen
check it high quality port behind the pc correct connection in the socket
Posted on Sep 27, 2011
Philips flat screen tv
Board for the screen has a bad component or a bad solder joint. It will need to go to a repair shop. It may be cheaper to replace the tv.
Jul 04, 2016 | Philips 47PFL7403D 47 in. LCD TV
Poor Picture Quality on Philips 42PFL7962D
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Dec 05, 2007 | Philips 42PF9956 42 in. HD-Ready Plasma...
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
Philips 42PFL5405h/12 - Black screen and no audio on turning on.
It sounds that the settings have been corrupted. It will be best to contact the authorized service center to make this set right. Beware, not to make any experiments hereafter. It's 'PHILIPS'
Jun 24, 2013 | Philips Televison & Video
Sep 27, 2011 | Philips Televison & Video
Philips tv set 29PT6231/79R. Good picture and sound feeding through VCR machine. How do I get it to play video tapes? My previous tv played through channel 7.
I'd suggest connecting the VCR to one of the composite inputs on the set (Yellow, Red and White cable). Select that composite input, then tell the VCR to play. This will you give a slightly better quality picture than going through the tuner as you did on your old TV set.
May 02, 2011 | Philips Televison & Video
Picture quality poor on certain channels,get all of bbc channels ok rest loss of sound and hick ups in picture
if all channels poor quality TV problem
if just one or tow channels bad quality not tv problem....
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Sep 27, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
