Question about Creda W100FW Front Load Washer
Washing machine dead
Used this morning went to 2nd load dead
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Dec 31, 2012 | Hoover Washing Machines
Washing machine will not turn on.
Hi just read your posting.Have you checked the power point for power with a toaster or hair dryer?If there is power to the machine then there are 2 reasons why it is not powering up.1st-- the drain pump is open circuit 2nd the control module is faulty.1st empty the machine by hand so you can look underneath the machine by tipping it back far enough to see the pump.Now the pump will either have a red or black fan on it ,or you will see no fan and that means you have the new style pump.please reply with the type of pump you have and if you have or can borrow an electrical test meter and i can guide you step by step to find out if the pump is faulty or the controller or both.
Jun 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
In mid cycle machines went dead. Power is ok at
http://www.servicematters.com/maytag_library/docs/16022808.pdf
use the service manual troubleshooting procedure above to isolate your issue and hopefully effect a repair.
May 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Mold issue on front gasket
A solution of bleach and water will do. Just wet the rag and rub it down well. When this is done you may still have the marks but the mold is dead. If you want it to be completely clean you may need to replace.it.
Jan 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frididaire front load washer won't lock
I find that I need to be extra gentle or it won't lock.  Try that.
Jan 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Creda W100FW Front Load Washer Logo
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
