Question about Toshiba HD-XA2 HD-DVD
408bc504 error code on hddvd disc
This error is showing up on one disc how do i fix it
Will not finalize disc Error E3 (etc.)
read you instr. manual and see the codes if you do not have it download
www.retrevo.com
God bless you
Sep 30, 2012 | Magnavox MDR515H HDDVD Recorder
Magnavox MDR515H will not finalize
clean the OPU unit ( objetive LENS ) WITH disk cleaner. and fix it.
otherwise read your instr. manual go to the section troubleshooting
or download your instr. manual www. retrevo.com
If the problem persist you must go to the repair shop TV for fix it.
God bless you
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Disc Error
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide....
Apr 07, 2009 | Nintendo Wii Console
Cannot read disc
Mar 29, 2009 | Nintendo Wii Console
Xbox 360 HDDVD Player
Check the region code of the disc against your consoles region code, if they don't match it won't it.
Also have you installed the updates for the HD Player, if not either download them via Xbox live or download them from here and copy to disc:
http://www.xbox.com/en-US/hardware/x/xbox360hddvdplayer/downloadredirect.htm Cheers
Jun 06, 2008 | Microsoft Xbox 360 Elite Console
Trying to play hddvd onhdmi player
i don't think this model plays hddvd you will need a seperate player for these discs.
you can only play normal dvds not HDDVDs
good luck
smeags
Dec 31, 2007 | Philips HTS-3555 System
Toshiba HD-XA2 HD-DVD Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
