Question about Garden
Clunking sound in first and second gear and chain slipping when i accelerate
When i accelerate the chain keeps slipping causing the bike to keep jerking when ever i open it up
    New Friend:
    Problem Solver:
  • 9 Answers
Try a new sprocket.
Posted on Nov 19, 2013
4 Suggested Answers
SpotBert
  • 231 Answers
SOURCE: Chain slips off bar
I would suggest adjusting the tension and cleaning and debris along the chain path (guide bar).
Here's the manual for Poulan PP4218AV =>
http://72.3.225.179/manuals/165555e.pdf
Look at page 6-7 for instructions to adjust the chain tension and page 16 for cleaning the guide bar.
Here's the link to other Poulan Products =>
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Posted on Jan 03, 2009
  • 360 Answers
SOURCE: Chain keeps jumping off
when you adjust the tension of the chain, ensure the tip of the bar has upward pressure applied to it. This ensures the tension is correct while in use. Improper tension adjustment can cause the chain to loosen in use and "jump" off the bar. Improper adjustment can also stretch the chain leading to the same result.
please take the time to give this solution a fix ya rated
clarkco
Posted on Mar 19, 2009
  • 4088 Answers
SOURCE: I have a Poulan 18
Make sure the chain brake is off (pull it toward you), then remove the bar mounting nut(s)/bolt(s) and the remove the side cover, bar, and chain. Clean the oil passages in the rear of the bar including two small passages that run from the larger holes out to the chain groove on each side. Clean the entire chain groove and make sure the end sprocket turns freely and is well oiled. Clean the engine face where the bar fits, then start the engine. Oil should ooze out of a small port in the engine case. If ok, then lay out the chain so that it can be inspected for bent links, dry/sticking joints, or missing/badly worn drive teeth. Inspect the sprocket on the clutch outer drum component for wear or damaged teeth. Make sure the pitch of the chain teeth match those of the drive sprocket (is this a new chain?). Check the hub bearing of the clutch drum for obvious wear. If all looks good, fit the chain around the clutch sprocket, then slip the bar into the the engine mounting space and work the chain over the entire bar. When setting the outer cover, make sure the adjuster tang fits into the related bar hole, then attach the clamp nut(s)/bolt(s), run up finger tight. Use the adjuster to set the chain tension--it should just pull the lower part of the chain up to the bar plus a little more. Check that you can move the chain by hand without any binding, then tighten the clamp bolts/nuts firmly. Recheck that the chain is properly tensioned. If not, re-loosen the clamp fasteners and re-tension the chain. When the clamp fasteners are tight, the tension must be rechecked. Hope this long-winded response helps!
Posted on May 14, 2010
What would cause my 26 inch avalon bicyle to make a clunking sound when shifting from low to high gear?And how do I fix it?
Are you going 1 gear at a time or trying to go from first to high. On some bikes you have to allow the chain go from one gear to the nest and up the line or it will make a noise.
Mar 31, 2015 | Cycling
Sounds like my chain has gone but how long can this last is it very dangerous can the chain come off at all? the teeth on the sprockets are still very good and sharp but does sound like its slipping s
You need a new chain, a worn chain will not match up properly with a new gear/cog. You can do this yourself, the chain should have a link that will come apart.
Nov 19, 2013 | Suzuki RF 600 R Motorcycles
I have a 03 yamaha vstar 1100 classic and here latley when accelerating hard in second gear the bike seems like the transmission is skipping (not slipping)... any ideas as to what in the tranny is causing...
Sounds like a bent shift fork. While accelerating you can feel the power cutting in and out quickly. The problem will get worse if you keep pushing 2nd gear till it slips. You can learn where (at what RPM) it wants to jump out and start shifting before it jumps out. The long term fix is opening the transmission and fixing the bent shift fork.
Oct 03, 2013 | 2003 Yamaha V Star 1100 Classic
Hi I purchased a second hand schwinn searcher sr suntour m2000 bike and I don't know how to use it properly I need a manual. I gear chain keeps slipping.
Bikes are SOOOOO generic and the components installed on them are almost always made by some other component manufacturer.
Almost any question you have can be fashioned into a search engine query and it will probably find video help.
"how to shift"
"how to adjust ...."
"gear slipping on bike"
You could contact the manufacturer or look around their website for instant answers before going out to generic help sites.
http://www.schwinnbikes.com/support/owners-manuals
Jul 19, 2011 | Cycling
My chain sounds like it keeps slipping
It is not slipping unless your sprockets are SHOT.
There should be about 3/4 inch play in the center bottom of your chain when the bike has a normal load on it (read YOU).
Now then, your clutch could be slipping ... have you adjusted it?
I hope this helps you
a
Oct 12, 2009 | Yamaha G5 Motorcycles
The bike won't engage when riding and it is making a loud clunking noise
Check the chain alignment may need to adjust shifter cable.
Aug 03, 2009 | Cycling
Hello! I have a 2002 Honda CBR 600f4i that i recently purchased. It had 6800 miles on it when i bought it from the second owner. My issue with the bike happens when i am cruising or have let off the...
anytime i get clunking on my old cbr i know its time to adjust the chain...too much slack will cause this usually. if you ride your bike real hard like i do mine all the time, the chain stretches but not all together evenly... only in small sections..so when you adjust a worn out chain your suppose to adjust it for the tightest section...but then when you check the rest of the chain its a lot looser and makes for noisy shifts... so i just buy another chain when it gets that bad. you'll know it time to change a chain when you can lift it off the sprocket and see daylight between them. also this clunking could be a loose axle or worn bearing?
Jul 12, 2009 | 2002 Honda CBR 600 F(4)i
The gear box is slipping out of gear when in 1st, 2nd and 3rd
You need a new transmission the gears are stripped off. I had the same problem
Jul 08, 2009 | 2000 Yamaha YZF-R6
Loud clunking noise when accelerating from a stop
I hate to tell you this but it soundes like it's in the differential. Take your bolts off your pumpkin and have some one rock the truck. I bet you have a lot of play and what you are hearing is the ring gear in there . It probabley has to much play in the two gears
Jan 10, 2009 | 1997 Ford Explorer AWD
04 Sportster 883 gearbox Clunk.
Big Twins clunk too, especially into 1st with a cold motor, even if you free the clutch off first. When I remember, I snick it into gear, pull in the clutch and roll it back and forward to free off the plates. And it still clunks. Sometimes, you will slip from neutral into 1st, almost with no effort, and no clunk and so smooth you don't believe it's engaged (but it is). Weird. I have smooth changes from 4th to 5th and back again, sometimes from 3rd to 4th, but 3rd to second and second to 1st are always a BIG clunk, even if you give it some stick to try and match the revs before changing down. I now go from second to neutral and then into 1st, which is not a lot of fun when you are negotiating a hairpin on Glenquaich at the time... A tighter primary chain seems to reduce the clunk, and there are those who say that auto primary adjusters/tensioners (does a Sporty have one of them?) reduce the clunk. Some disagree... Assume you find it's much better when it's hot..
Nov 20, 2008 | 2007 Harley Davidson XL 883 Sportster
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
