Question about Siemens Gigaset 8825 Cordless Phone
Base won't register & phones don't work
My phones stopped working. no power cut. All the phones are flashing "base" I've put a new battery in the base station, unplugged it and waited. When I reset the base I now get "registr failed". The al285 is the base station and we have 3 older models as bases 1-3. Help!
  • 518 Answers
SOURCE: Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Posted on Jan 23, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Posted on Feb 11, 2008
SOURCE: Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Posted on Aug 27, 2008
diodeic
  • 1622 Answers
SOURCE: My Siemans 8825 failed.
Hi, to make it easy for you, let me show you how i did mine through the link below...It helped a lot.
You can try and see your self and give me a feetback..ok
http://www.barclayent.com/Cordless/siemenscordless.htm
Hope it helped.
Posted on Apr 18, 2011
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Nov 12, 2010 | Uniden Lands Phones
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Jun 21, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
Try this:
Geno
Jan 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
Jan 27, 2007 | Vtech i5871 Cordless Phone
Siemens Gigaset 8825 Cordless Phone Logo
75 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
