Question about Whirlpool Washing Machines
Whirlpool GB AWOD 6707 intermittent spin post cycle. Error code F07
Whirlpool sixth sense washing machine does not always achieve full spin. Heavier loads seem to yield full spin results, however this problem only appears to have occurred recently.
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    barkencoa
    • 3463 Answers
    SOURCE: Ariston Front Loading Washing Machine error code F07
    Error code F07 is indicating that the heater relay is stuck for one reason or another.
    This could be a board problem, as this where the relay is located.
    However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
    Plz rate my solution.
    Thanks.
    Posted on Jan 13, 2009
    jonniewalker
    • 1031 Answers
    SOURCE: error code f22 whirlpool duet wash cycle
    f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
    If you're getting an F22 error, you will want to check anything to do with the door latch switch.
    Posted on Mar 14, 2009
    sclarke7
    • 222 Answers
    SOURCE: Getting HF error, on Whirlpool Front load washer
    No water detected entering machine or Pressure switch trip not detected.
    If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
    Or
    If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash2_bing.gif.
    Press PAUSE/CANCEL twice to clear the display.
    • If there is no water in the unit:
      1. Make sure that both valves at the water source(s) are turned on all the way.
      2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
      3. Verify inlet valve operation
    • If there is water in the unit:
      1. Verify Drain pump operation
      2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
    • Verify there is not a siphon problem
    • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
    • Check all hoses for possible leaks
    • Verify pressure switch operation
    • Verify flow meter operation
    • Verify CCU operation
    Posted on Mar 22, 2010
    SOURCE: Whirlpool washing machine agitator problem
    Simply buy the "doggies" and install it them
    Posted on Feb 22, 2011
    Hi, I have a Whirlpool AWOD 5526, it is probably about 11 or 12 yars old (so I'm not hopeful!) and until now has always run without problems. I had a filter clean error code about 6-8 months ago which I...
    f7=short circuit failure,ie =any number of small problems .But in this case I suspect a water flow problem,has the machine been moved and replaced ,,what im saying is the main water supply getting to the machine is a likely cause to show a f7 code,if not look at the water in as this is the likely problem.,Adrian....
    Dec 13, 2014 | Whirlpool Washing Machines
    Tip
    UE Error Code for LG Washing Machines
    If you are getting a UE error code from your LG washing machine then you need to know what is causing this code. This UE error code is caused when there is an unbalanced load condition sensed by the washing machine. There are a few things that can cause this and ways to correct it.
    If you are doing a load of wash that is too small, this can allow all of the wash to be on one side of the drum. Single heavier items will not work well and will cause this error when spinning. Very light single items may work, but for heavier items you will need to add more to the load to get it to work properly.
    If you have a load of heavier items like blankets, and sheets, you may have to stop the machine and spread them around the drum evenly before it will spin properly. Even jeans, shirts, and pillow cases can sometimes all end up on one side of the drum and cause it to become unbalanced. After spreading the items around the drum evenly, try to restart the spin cycle.
    If you hear your washing machine slowing down and tumbling a few times when trying to spin, it may be that you machine has a option on it that tries to redistribute the load on its own if it senses an unbalanced load. The machine will try this a couple of times before it will stop and give you an error code.
    If you need to reset the code at any time you can do this by unplugging the washing machine and then holding in the start/pause button for 5 seconds. Plug the washer back in and the code should be clear.
    http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
    http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
    http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
    http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
    http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
    on Mar 15, 2010 | Washing Machines
    I have a Whirlpool WFS1273AW with error code F07
    "F07" Motor Control Unit Error
    The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). Check the MCU and the drive motor.
    Mar 30, 2010 | Whirlpool Washing Machines
    F07 error message
    F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
    Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
    Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F07-AWM 9000
    The F07 indicates a Motor Control Unit (MCU) Error.
    1. Disconnect mains power and unplug unit.
    2. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    3. Check the MCU
    4. Check the Drive Motor
    5. Check the Wire Harness
    6. Reconnect power and plug unit in.
    7. Check the MCU operation by looking for movement of the drive motor, and check drive motor for fully powered rotation.
    8. Replace failed component. Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
    Select PAUSE/CANCEL twice to cancel the cycle.
    Select DRAIN/SPIN if there is excessive water in the washer.
    Re select cycle and select HOLD TO START.
    Oct 26, 2009 | Whirlpool AWM9000 Front Load Washer
    F07 occurs at end of first rinse cycle
    Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Thanks.
    Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
    Spin cycle
    the machine has sensors within it that detect off balance loads, very possible that the 1 or 2 items are not enough to correctly balance themselves, so the machine will never achieve full speed spin.
    Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Hotpoint WD860 problem
    washer wf860 showing f07 error. why
    Mar 04, 2008 | Hotpoint Washing Machines
    Washing Machines Logo
    Dan Webster
    Dan Webster
    Sal De
