Question about Hotpoint HSS25GFP Side by Side Refrigerator
My converter 220 V - 110V got damaged. What's the power consumption of the refrigerator ? How many wats ?
  • 283 Answers
Check the amps rating on the model sticker, multiply by your line voltage, usually around 120
Posted on Nov 19, 2013
Codes for 2010 Nissan titan
Common Problems That Trigger the P0422 Code
Defective Catalytic Converter
Engine misfires have damaged the Catalytic Converter
Internal engine damage resulting in high oil consumption and/or a leaking Head Gasket has damaged the Catalytic Converter
Common Misdiagnoses
Oxygen Sensor(s) are replaced when the real problem is a damaged Catalyst
Catalyst is replaced when the real problem is internal engine damage, which is producing elevated emissions levels
Catalyst is replaced when a misfiring engine is the real problem
Oct 03, 2017 | Nissan Cars & Trucks
Hi, what is the power consumption wattage of Kenmore 795.51032.011 refrigerator
Electrical consumption is indicated on plate with unit info.
Jul 04, 2017 | Kenmore Refrigerators
Po430 trouble code
P0430 - Catalyst System Efficiency Below Threshold Bank 2. The most common cause it the three way catalyst converter Bank 2. Common Problems That Trigger the P0430 Code
Feb 19, 2012 | 2005 Dodge Ram 1500
What is the average power consumption (watts)? What is the start-up power consumption?
Sir / madam
Horsepower (HP) is the name of several units of measurement of power. The most common definitions equal between 735.5 and 750 watts. Horsepower was originally defined to compare the output of steam engines with the power of a draft horses... In refrigerator the unit use is horsepower(HP) 1 HP = 750 watts
Jun 21, 2011 | Refrigerators
Want to know water and energy ratings of WFL2000AU.
Here you go, probably more than you wanted J
Energy Consumption per Wash: 190kW/yr warm wash
Water Consumption per Wash: 72.6l
ApplStandard AS/NZS 2040.2 (2000)
Brand BOSCH
Cap 6.50
CEC_ 190.00
Cold Wat Cons 72.60
Conn_Mode Cold
Country Thailand
Depth 600
Height 820
Hot Wat Cons 0.50
Model No WFL2000AU/WFL2080AU, WFL2400AU
New SRI 4.39
New Star 4.00
Prog Name Cotton 40C, 1000RPM
Sold_in Australia, New Zealand
Test Prog Time 123.60
Tot Wat Cons 73.10
WEI .658
Mar 07, 2011 | Bosch Washing Machines
I have bought Rancilio model: classe 6E 2GR/C is it 3 phase or single phase power input? what is the maximum power consumption of this machine?
It should be single phase but it can be converted to 3 phase power. Max power will consumption will depend on the size of the element that is installed. I do not know if you have a 6300w or a 5000w element. There is a face plate on the front with the power consumption.
Jan 24, 2011 | Rancilio Classe 6 E 2 gr Espresso Machine
I just purchased a lasko model 5805 ceramic heater. What's the cost to operate.
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
Dec 31, 2010 | Lasko Ceramic Heater
Loses power after 15 minutes. sits for 15 minutes and then runs f
Silly question
You got the code PO-420 Catalyst System Efficiency Below Threshold (Bank 1)
That is the converter,don't these places people go to ,tell you what codes they pulled?
O2 Sensors
Coolant Temp Sensor
High Fuel Pressure
Bad Converter
Cylinder Misfire
Damaged Exhaust System Pipe/Muffler
High Oil Consumption
Etc, Etc
May 26, 2010 | 2001 Honda Civic
Engine light came on code #p0422 main catylist below threshhold bank one?
  • Defective Catalytic Converter
  • Engine misfires have damaged the Catalytic Converter
  • Internal engine damage resulting in high oil consumption and/or a leaking Head Gasket has damaged the Catalytic Converter
Apr 09, 2010 | 2000 Kia Sportage
Converter for my sony grand wega 60" to work in the U.K.
The specifications for this set list the power consumption at 250 watts so allow for a little extra and go with a 500 watt converter. Also, make sure the converter will change the UK's 50Hz power to the 60 Hz power required for the set. To be exact, the converter must change the UK's 230 volt 50 hertz power to 120 volts (100 will do) 60 hertz. Do NOT attempt to run the TV on 50 hertz power as it is likely you will damage the set
Nov 29, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
44 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
