Fisher paykel E388 freezer beeps twice when the door is opened, what does the fault code mean?
SOURCE: Fisher & Paykel intuitive eco washing machine
How do I fix a code 37 on my machine
Posted on Aug 31, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Posted on Sep 30, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 343 Answers
SOURCE: iw712 fisher and paykel washer has fault code 37 w...
37 is drain error..There could be electronic reasons, but the most common problem is that there is a clogged pump or something is jammed in the pump impeller... Empty the machine of water and lean back against the wall so you can get access to pump, which is clipped to the bottom of the drum..Try turning the fan and see if the pump is blocked'/jammed.....Disconnect the wires and rotate the pump motor anticlockwise...It will be prevented from turning by a small plastic latch. Unlatch and remove pump motor...Remove any detritus and refit pump motor....If the motor resistance is less than 33 ohms (230volt) or 7ohms (110volt)..the pump motor itself might be the cause of the fault code, and should be replaced......This is a very simple job for a tech...Good luck....Nomess
Posted on May 24, 2010
Fisher paykel freezer it only has audible alarms and i dont know what its trying to tell me
Looking for specific answers? Provide more details.
  1. Model number of freezer will help.
  2. Does alarm beep when door is closed?
  3. Does alarm beep when door is open?
  4. How many beeps? The amount of beeps will indicate the fault code. From there, more information can be provided.
Nov 06, 2016 | Fisher Refrigerators
Why did door alarm suddenly start going off every time I open the fridge or freezer?
Hi Christine.
When your F&P beeps, it's indicating a fault code - count the beeps which will relate to a fault code. 17 beeps would indicate an issue with the freezer fan.
Could be the reed switch (door switch).. amount of beeps will indicate the fault code.
Dec 14, 2015 | Fisher and Paykel E402BRXFDU Bottom...
The door alarm of my fisher and Paykel E372B fridge goes off when the door hasnt been opened for a number of hours. How can I stop this.
You would notice that when it beeps, there are a series of beeps, which relate to an error code - also, the temperature panel would be most likely flashing the same amount of times the beeping occurs. The code relates to a component failure that the active smart system is having problems with.
For example, 17 beeps would be error code 17 - which relates to the freezer fan is drawing less current than is expected. Either the wiring is open circuit or the fan is faulty.
Feb 18, 2015 | Fisher and Paykel Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
F&P Dishwasher Fault
Most likely you have fault code E1 which means door is not shut properly. It is likely the door springs need adjustment as the door might be opening mid cycle.
Refer manual
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/599350D_DW60ugm_AUSGw.pdf
Mar 18, 2014 | Fisher and Paykel Dishwashers
Fault code F2
Hi when the door is opened for to long alarm will beep to let you know
Mar 08, 2014 | Fisher and Paykel Active Smart E522B...
I have a Fisher Paykel E388 upright freezer which freezes in the bottom couple of drawers but not toward the top. The motor is running and fan spins when you open freezer but stops when door is opened. Any...
Cold air always settles on the bottom Check the door seals above the cold area . Check for broken seals ,cracked seals and seals that are not touching the frame. Place a thin piece of paper between the seal and the frame and close the door . If the paper falls or is easy to pull out that may be your problem. Test at various points around the door.
Apr 06, 2013 | Refrigerators
Hi friend has a fisher and paykel refridgeator and its sounding an alarm of one beep and then 3 or 4 long beep followed by a short beeps then then a single beep its a top freezer model and the refrigeator...
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 11, 2010 | Fisher and Paykel Active Smart E522B...
Fridge beeping
the beeping is an alarm certain lights on the display will be flashing when it is beeping record which lights are flashing this idicates a fault code then post your results and i will tell you what the fault code is and what the problem is likely to be :)
Jun 07, 2010 | Fisher and Paykel Active SmartĀ® E522BR...
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
