Question about Bush 5693D 24" TV
42"flat screen not getting power,goes on for a while and then goes off
    Habit-Forming:
    New Friend:
  • 155 Answers
Usually means power supply problems. Unplug and check inside set near on/off button where power comes in, look for burnt or damaged components.
Posted on Nov 19, 2013
Screen goes blank, but sound is on
Most likely a bad power supply. If this is new I would send in for warranty. If outside of warranty then pull this apart and find out the board model and number. You can find most online.
Apr 09, 2014 | RCA Lg 42ls5700 42" 1080p Flat Panel...
Phillip 42 flat screen plasma blinking red light 6 times
most likely the power supply, buy it from http://www.shopjimmy.com/ they have the best prices anywhere. and techs to help if needed
Sep 06, 2012 | Philips 42PF9631D 42 in. Plasma Television
HI, I have a 42 toshiba regza tv that is 3 years old when watching tv the screen goes blank and the sound is still there i power it off then back on and the picture is fine. Somtimes wont happen for days...
If you are using a hdmi cable take it off and switch to component cables if the problem goes away keep it that way. Sometimes the hdmi hookups have bugs like this.
May 25, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Flat screen tv problem
42PF7320A: 7 blinks is missing 8.6VDC from supply -- connector CN-1M46, pin 3 (out of 11 pins), goes from power supply to main/input board.
Apr 21, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
The screen starts flashing and the picture goes out completely on our vizio flat screen
Technically the picture is still there an lcd is lit up by powerful backlights called ccfl's (cold cathode flurecent lamp) and they are powered by an inverter which takes the reletively low voltage up to a high or higher voltage to power them, if the inverter or inverters need changing it's not so hard to do. to confirm this shine a torch on the screen when it goes black there should still be a picture> :-)
Mar 22, 2010 | Vizio GV42L 42 in. LCD Television
Sharp aquos 42 1080 if the picture goes and have sounds can you fix the problem? Is there a fuse you can change or do you need a tech to get it fix?
If the screen is still backlit it is most likely a tcon bd . Also does it happen on any input to the tv? If yes and the screen is not backlit it is possibly a inverter or power board issue
Roy
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
42 inch lg tv powers on,goes off after about 30 seconds
hello my friend you have some loose connections on the digital board.this board is located right in the top center of the tv.if you do not have repair skills call the repairman he should not charge you too much for this job. good luck
May 31, 2009 | LG 42LC2D 42 in. LCD HDTV
Dell 42 inch plasma has no image or sound
needs new panel and a updated power board. firmware must be 51-7 (current)
Jan 21, 2009 | Dell W4201C 42 in. Plasma HDTV
Green blotches on screen
your vs and va need to be adjusted on power supply i can walk you through it but requirs volt meter and taking the back panel off tv
Jan 15, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Hitachi 42"
Its impossible to say without knowing more than that. If the TV does not detect any signal on whichever input (other than CATV) your on, it will power down. Make sure you are getting an input signal and make sure you are on the right input on the screen.
More info on your problem and i could probably help you better!
Jan 11, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Bush 5693D 24" TV Logo
24 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
