Question about Hoover Dryers
Wiring diagram for Hoover VHC681B - Hoover Dryers
How is Hoover VHC681B door seal fitted? Does the thin outer flange go into the groove with the square section or is it supposed to overlap the body of the machine?
the wider end fits onto the tub.If you put a long thin screwdriver through the door interlock hole to hold the retaining spring (the stretchy wire type) you will find it will go on easier.
Feb 24, 2015 | Hoover Washing Machines
Please can you provide a wiring diagram for my fridge thermostate it is a hoover supreme double door
There should be a technical sheet/booklet stuck in under your fridge. If you look around in the back around the condensor you should locate it.
Dec 02, 2010 | Hoover Refrigerators
How to wire timer on hoover dryer ?
there should be a wiring diagram in the back right hand of dryer,
Oct 21, 2010 | Hoover Dryers
Dryers Logo
83 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
