Rinnai Energy Saver 431 Error Code xxxoox
Heater will stop with error code xxx000x We have had this amazing heater for approximately 8 years. 3 years ago occasionally the heater stops functioning overnight with flashing lights xxxoo and red on light. (low 60 64 and on are flashing) I cycle the power (with the flashing red button) and the heater starts up, and functions flawlessly for days if not weeks. It appears that they issue has been happening more frequently but I have not tracked timing. The only correlation I can find is it appears that it errors out on windy days making me think it may be a faulty pressure switch. I installed this heater online and installed it myself and think there may be issues with the warranty as a result of that. Thanks Greg
Therinnaiguy
  • 1420 Answers
SOURCE: error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
Posted on Nov 07, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai Heater - error message "12"
An error code of 12 on your heater means a flame failure has occured. It could be the following: Flame Rod dirty, Obstruction in burner, improper gas pressure, or a bad ignitor board. I am suggesting you get a technician who is familiar with Rinnai products to check out the above items.
Posted on May 27, 2008
SOURCE: mr heater 75,000 btu kerosene heater
I got this error when I had increased my air pressure to 5.5 lbs. Cut the pressure back to 4.5 and it has been running fine for the last three hours. At 5.5 it got WARM ... solid red hot cone and flames coming around the outside. Had been having problems with it cutting off for no apparent reason in really cold weather. Took the pump apart and cleaned it and checked for clearances and reassembled but it did not help much. Will schedule it for a total pump replacement with new filters asap. Pump parts and filter are not that bad. Should come in under $50.00
Hope this helps
I also turned the thermostat back a little off of full on.
Mike
Posted on Feb 04, 2009
SOURCE: Panasonic Whisper Warm Heater Thermal cutoff. How to reactivate?
I had the same problem and mine was cause by a blown fuse. It's not too hard to fix. Remove the cover by pulling down and squeezing the wire arms on each side. You need a VERY long screwdriver to remove the entire motor/fan/light assembly from the housing (8 screws total). Place the assembly on the floor and look for the fuse on top. The fuse is on the motor, not near the heater portion. It is a ceramic, not glass, cylindrical fuse, 20 amps, 125 volts. This fuse is sold as a microwave oven fuse & costs about 2 bucks at a hardware store. Replace, reinstall, and you're done.
Posted on May 21, 2009
  • 120 Answers
SOURCE: Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Posted on Jul 21, 2010
What is error code 99 on my Rinnai energysaver wall heater
Check the flue for blockage of exaust air flow ,ice,snow,birdnest ect.
Feb 18, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai 556F Heater and I set it to a specific Temperature and a temperature higher is always flashing. What is wrong?
The temp you are looking at may be an error code. 72 Room sensor, 68 Over heat, 76.80 Room sensor short, etc. What is the exact code??
Tom
Oct 14, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
I rent and have a Rinnai Energy saver 556F. I have it at 64 and the light blinks for 68. I would like to know why. It is 56 out side now thank you
Shadow,
The 68 you see is an error code. It means you have had an over heat situation. You should be able to clean the filter and fan area and restart. Turn the heater off and on again, that should reset everything and you should be good.
Tom
Oct 06, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Flashing code 99
Error code 99 has to do with the flue pipe being blocked. You could have ice or frost on the exhaust or air intake. This reduces the combustion air to the unit which in turn stops the fuel flow.
Tom Hawkins
hawkins111@gci.net
Dec 21, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 403 FT
who did you talk to at rennnai?
let me know i deal with them on a buisness leval.
Mar 27, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code 11 on my rinnai
Nov 06, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004fa
page 35 of the following: http://www.rinnai.us/Rinnai.aspx/FileLibrary.aspx/DealerResources.aspx/DocumentsLibrary.aspx/WallFurnacesDirectVentMainHeatSource.aspx/RHFE1004FA.aspx/GeneralInformation.aspx/456RHFE1004FAManual32003.pdf.aspx hope this helps :)
Dec 24, 2006 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
