Where do I find my ITR12 form? - Computers & Internet
Is it mandatory to provide form 56b with form 56a?
Can you be a bit more clear? In what kind of PC Laptop?
Dec 24, 2012 | Toshiba Satellite PSPA0U01S006 Notebook
Find the linear equation in slope-intercept form
The equation of a straight line can be cast into several forms: functional form, general form, symmetrical form. The functional form is the one usually known as slope intercept form.
In the functional form, y=ax+b or sometimes y=mx+b, the factor of the x-variable (a or m as the case may be) is the slope of the straight line, and the value b, is the ordinate (y-value) of the point where the straight line cuts (intercepts) the y-axis.
Since you say nothing about the particulars of the line that interests you, there is not much more that anybody can help you with.
Mar 25, 2012 | SoftMath Algebrator - Algebra Homework...
The form at http://www.thecondoexperts.info/form/basic.htm is not working. That form is on my landing web page at www.thecondoexperts.info. Can someone tell me how to correct the form in order to make...
For starters, your form named basic.htm has an incorrect function:
FORM
ID="frmMain" ACTION="http://www.thecondoexperts.info" METHOD=post>
should be
FORM ID="frmMain" ACTION="http://www.thecondoexperts.info/request.php" METHOD=post>
The request.php takes the form information when you press the Submit button, processes it and sends out and e-mail to your account and the customer. If there is an error in the form the request.php will send the customer to an error page instructing them to try again.
Oct 03, 2011 | Computers & Internet
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
Form feeding
try puting a piece of cardbord under the paper but tape it 3mm from the roller.
Jul 31, 2009 | AMT Datasouth ACCEL-6350 Matrix Printer
Forms
The book says:
Besure auto ret. is off.
Hold forms key an press form # 01- 99, app light goes on and forms light blinks.
Inset form at 0 paper scale position. Pull paper bail forward form will load to the first marked position.
Type info and then phrase T/W will move to the next marked position.
The full instructions are about 4 pages long, if you have a fax # I can send them to you
DockyO
Sep 08, 2008 | Lexmark Wheelwriter 1500 Typewriter
Need to scan a form to be filled out to computer
If you scan a form onto a computer, it won't behave as a form by default. This is because the computer is just storing a picture of the form, and doesn't see it as a form.
To make a scanned form into an electronic version, you will need some software that lets you define the regions of the form that can be filled in by the user. the full version of Adobe Acrobat lets you do this, as do the less expensive programs CutePDF Professional or PDfill.
Basically, you scan your document into a pdf format and use the aforementioned software to define which regions on the form should have typable text, checkboxes, etc., then you re-save it as a fillable pdf.
This works well, I do this with all my rental applications, etc.
There is a little bit of learning required to do this, but if you spend some time with the program and its helpfile you'll be creating forms with the best of them!
Apr 22, 2008 | Office Equipment & Supplies
How to make Forms work
hi there...not to worry at all....al the links are working perfactly all right....i can accecc all the pages...
contact us form
registered users form and
Information form
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 13, 2008 | Computers & Internet
Restict closing the main form when some controls on the subform are empty
Hi there. I didn't notice this was so old until I had already worked on it for some time. Did you get this the way you want it? If not, I suggest either using a BeforeUpdate control to ensure the condition is met that the subform contain data, or validate the particular field(s) with isnull. Thanks for posting back if you still need help, or otherwise rating FixYa!
Oct 03, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
