Question about Microwave Ovens
My haier microwave oven is not working every thing is ok except heating
Heating performance is zero
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Please make this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
my haier microwave oven  is not working every thin - f4711d36-c189-487e-af05-09a1e9f7b684.gif
Posted on Nov 19, 2013
4 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: Microwave Oven not Hot
Common faults or combinations of faults:
Main processor board is defective.
Control devices, thyrisistor or relay on the processor board has failed, and or the drive components to this device.
Defective safety switches.
High voltage power supply failure. Usually the high voltage rectifier, and or the power transformer, and or the main high voltage capacitor, and or the magnetron.
I suggest that you DO NOT mess inside your microwave oven. This is probably the most dangerious appliance in the home next to the TV set. There are very high voltages employed. If you do any maintenance on a microwave oven and if something is not right there is also risk of high frequency EMF radiation exposure.
After opening a microwave oven and doing service on it. We always did a ratiation test to make sure that there is no leakage while it is in operation.
I suggest you do some reading at the links below.
Microwave Oven Safety:
http://www.hps.org/hpspublications/articles/microwaveoven.html
http://www.fda.gov/cdrh/consumer/microwave.html
http://www.selfgrowth.com/articles/Microwave_Oven_Safety_Tips.html
Excellent article about microwave ovens:
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Posted on May 26, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: My Maytag MMV4205 Microwave Oven runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
heatman101
  • 43501 Answers
SOURCE: in model spacemaker xl1800 no heating but all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Posted on Sep 30, 2010
How do i adjust power level
There are no heat levels on a microwave oven, only power levels. I am not aware of any method of checking the power level except to boil water. Boil water at each level and time how long it takes to boil. The lower the power, the longer it should take. If there are no differences in the time, the oven is not functioning as expexted.
Sep 13, 2014 | Haier Microwave Ovens
Zero heating performance
Nov 19, 2013 | Haier Microwave Microwave Oven
Everything works ok on my Ge microwave oven JVM1650 except it will not heat up food
heatman101 ;';';'
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave recently stopped heating things for some weeks now. Its working, just not warming things. Please what should i do?
heatman101 ';'
May 24, 2011 | Haier MWM11100TW / MWM11100TB 1000 Watts...
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
A child burnt popcorn in our GE Spacemaker microwave. Now, everything works except for the heat. Panel works, light works, turn table works...no heat. Help pls.
Sadly popcorn kills more microwave ovens than peiple imagine. You can get an estimate on a repair but I believe you will probably decide in the end to replace it. Same exact thing happened to me............expensive popcorn!!
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works ok except strange hum and no heat
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
If it is under warranty you are golden. If not, you should get an estimate, as many new microwaves are now in the 50 dollar to 99 dollar range
May 21, 2009 | LG LMV1650ST Microwave Oven
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
