Question about Haier Microwave Microwave Oven
Zero heating performance - Haier Microwave Microwave Oven
    Top Expert:
  • Haier Master
  • 12,223 Answers
Make this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Posted on Nov 19, 2013
My haier microwave oven is not working every thing is ok except heating
please make this test and fix it. God bless you
Nov 19, 2013 | Microwave Ovens
Microwave wont turn on and heat
follow this steps and fix it.
1)
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
2) do-not heat
God bless you
Sep 30, 2013 | LG Microwave Ovens
No heat generated in microwave or convection oven mode
I just read that starting the microwave as usual and then slightly pressing in the handle (you can hear the heater(?) come on will make the heat come on. Tried it and it works. My repairman told me it needed a new magnetron ($700) but that was totally wrong. I will be trying another repairman to replace handle mechanism.
May 11, 2013 | Sub-Zero MW24 Microwave Oven
Microwave timer doesnt ping off
this is probaly a clockwork timer you are talking about sounds like the contackts are stuck together in the timer pull knob off take screws out probally 2 disconnect wires from timer and replace they are not so expensive
Mar 28, 2013 | Microwave Ovens
Oven not working. Replaced an element, but oven will not heat up. The stovetop works fine, but the oven does not heat up.
check the continuity or resistance.
Now if its zero reading try to check your termination and also check the fuse or thermal cut out or thermal overload if it is busted or burn try to used also your tester.
But if there a resistances try to reset.
Mar 04, 2011 | Frigidaire FMV156DC Microwave Oven
Doesn't heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
satq
Jun 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Intermittent heat in microwave
heatman101
fgssg
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave not heating...power going to it...turntable runs, lites on...no heating
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capicitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
Microwave not heating food
check magnetron and related circuit, and control unit and highvoltage section..
Nov 19, 2007 | Microwave Ovens
Haier Microwave Microwave Oven Logo
62 people viewed this question
Top Haier Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Haier Microwave Oven Expert? Answer questions, earn points and help others
