Question about Sector 42,195 Marathon Timer R3251695015 Watch for Men
I am not able to set analog time
Hi, after a battery change I am not able to set the analog time. Altough I followed the manual and set the hands time in the right menu, the hands moved to a wrong time. How can I solve this problem?
3 Suggested Answers
SOURCE: seconds hand moving by 4 sec at a time?
yes, that's the low battery signal
Posted on Aug 23, 2008
  • 2501 Answers
SOURCE: Setting Analog Hands
I can't find the instructions for this watch but Casio instructions may be similar, so you could try this:-
Press the "mode" button until you get an abbreviated message for hand setting mode (HS?)
When in this mode, I expect that two of the other buttons make the hands go forward or backward.
Some experimenting will be required. When you have finished, press the mode button until normal operation has been achieved.
Posted on Feb 11, 2010
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
Cant get analog to sync with digital time. I live in SC and I try to set the time for 22:36 but then the analog set it to 12:36 am. :/
First set your local time, date and year and then run the "home positioning" (H-SET) procedure following manual instructions.If no any other problem exists, normally hands will "follow" digital time when watch is set back to time mode.
May 08, 2013 | Casio G-Shock GA-110-1B GA-110-1 Mens...
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
Mar 31, 2013 | Casio Watches
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
How to set clock time on casio aw- 81 time
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
A - upper left button
B - upper right button
C - down left button
D - down right button
In the Timekeeping mode, Precc C six times to enter to Hand Mode
Hold A until the current digital time start
Hold D to advance the analog time
If you like advance the analog time a long away, press D + B the same time. Press A to exit the setting screen.
To return to the Timekeeping mode press C
Aug 18, 2010 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
How do I set the analogue hands so hat they tell
Push the lower left mode button (C) until the bottom line of the LCD is "HS". Then press either to top right (B) or bottom right (D) buttons to change the position of the hands. The mode button selection is shown on page 1 of the manual. Changing the hands is described in the Analog Timekeeping section on page 4 of the manual. The manual is currently available here: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf
Dec 06, 2009 | Casio WVA105HDA Wave Ceptor watch
How to set the digital and analog as the same time
They are supposed to move in unison, if you are setting the digital time and the analog is not moving, there is a problem with the watch and it could need service. Here is a link to the manual for the watch, the movement for the Blue Angels is a C300 and you will see the manual also states the time mechanisms move in tandem.
http://www.citizenwatch.jp/support/pdf/coa/c300.pdf
Citizen does have service centers all over the globe, I am sure you can get the watch fixed if it does need service, You can find the local service center at the Citizen web site. Hope that helps.
Jan 30, 2009 | Citizen Blue Angels Skyhawk Watch
Cant get Casio 4303 to enter receive mode
See: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
and go to the section "Adjusting the Home Position"
This is a "calibration" procedure to get the motor of the analog movement back to the home position of 12:00. This worked for me, after replacing the battery.
Note that in this procedure the hour hand does not move separately, but moves with the minute hand. So to get the hour hand to move, you have to let the minute hand spin a number of times until you get the hour hand up to twelve o'clock.
Jul 16, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Analog will not sync with digital
I just bought a 4756. Hard to follow that manual.
In the end I used these parts of the manual
Step 1 was to set the correct time zone (off PT or pacific time to ET eastern Time.)
Step 2 was to do a manual receive of the radio time.
Step 3 was to Home all the analog hands so they all pointed to 12. see manual
Step 4 then I hit B button - top right by the 2 and everything spun around to the right time received from the manual received time.
Dec 21, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Sector 42,195 Marathon Timer R3251695015 Watch for Men Logo
Top Sector Watches Experts
staicuma
Level 1 Expert
aravind shet
aravind shet
Are you a Sector Watch Expert? Answer questions, earn points and help others
