Question about Riccar Sewing Machines
I need a needle bar for a riccar rl-924 dr overlocker
The screw securing thread guide has been snapped of in the needle bar,the screw has a shank halfway down which the outer thread guide plate fits on loose,the inner plate is held tight with the screw
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
bargainbox
  • 1388 Answers
SOURCE: Help, Janome Ezy Lock 304D Overlocker!
Although the tension units on your machine are of a different configuration, always thread from the right spool first and then each one to the left.........ONLY in that sequence !
now take a look at this sewusa site for a better view of the actual routine through the thread guides.........as I say, the tension units are different, but the sequence is the same, just use the image from above to see which one is next........this chart, just as the one on the fold down cover of your machine need to be followed one thread at a time from R to L
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 08, 2008
akylas
  • 26 Answers
SOURCE: thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
Posted on May 28, 2008
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
  • 11 Answers
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Posted on Jun 16, 2009
I have bought new needles for my Riccar overlocker now the stitching is loopy and messy
Verify you are using the correct needles for your machine. Some needles vary by a fraction of an inch but will make a big difference in serging success.
Remove all the threads from the machine.
(Always cut the threads below the spools, raise the presser foot, and pull the threads DOWN through the needles--Never pull up!)
ALWAYS RAISE the presser foot when threading.
Be sure to always thread each thread in the proper order--threading out of order will usually fail.
Rethread from the beginning and give each thread an extra little tug when threading the tension disk.
If a thread breaks, it is usually less frustrating in the end to remove all the threads and rethread from the beginning. Trying to rethread a broken thread will most likely cause problems.
Apr 25, 2017 | Riccar Sewing Machines
Twisted wire guide for the thread above the needle
Slide it onto the needle clamp from the bottom before you attach the needle clamp to the needle bar.
Mar 14, 2014 | Brother XL-5130 Mechanical Sewing Machine
Problem with an overlocker that does not overlock
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
Jan 20, 2014 | Janome Sewing Machines
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
How do I remove the needle from my Brother Overlocker
HOLD needle before you turn needle clamp screw towards you to loosen. I emphasize holding needles a's you remove them because many sewists have accidentally DROPPED needles down into their machines! TURN OFF POWER & UNPLUG! You will have two needles (standard #11 and a #14 but check your manual, please!). Although the needles will be same length, the left one will APPEAR higher when you insert into the needle bar. The flat shank goes to the BACK, more "rounded" side of needle/s facing you. Jimmy
Apr 04, 2012 | Sewing Machines
Need instruction manual for riccar RL-613 overlocker
All Riccar manuals can be found for free on their website. Here's a URL:
http://www.riccar.com/help/manuals/
Apr 11, 2009 | Riccar R1570 Mechanical Sewing Machine
Machine not sewing
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Bargain Box
Feb 01, 2008 | Sewing Machines
Sewing Machines Logo
69 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
