Question about Bosch Ovens
Bosch hbn43m560b oven heating up slowly
When oven is switched on its slow to heat up, turn oven off and then back on it starts to heat up
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Check connections
Posted on Nov 22, 2013
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
  • 1462 Answers
SOURCE: oven heats up then switches off
there is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
Posted on May 20, 2007
SOURCE: dacor epicure electric oven
On my Dacor oven whenever I use the self cleaning feature it trips the breaker and the oven doesn't heat up. It can be reset, but you need to take off the front panel and reach way back for the red reset button.
Posted on Nov 05, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    TheMobilian
    • 8220 Answers
    SOURCE: Oven appears to start, takes forever to preheat,
    This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
    Posted on Feb 26, 2010
    Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
    Bosch gas oven heating slowly - takes about 1 hour to reach 150 - 200 degrees. When trays placed in oven, temperature decreases cooking very slowly
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    May 19, 2011 | Bosch HBL 5032 Electric Single Oven
    My Bosch oven will not heat
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Jan 04, 2011 | Bosch HBL 445 Stainless Steel Electric...
    Oven does not heat to selected temperature.
    heatman101
    Dec 13, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
    HBN91 our bottom oven is not heating up
    heatman101
    Dec 12, 2010 | Bosch Ovens
    Does not turn on
    heatman101
    Dec 10, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
    Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
    If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
    I have A Bosch HBN32 oven which has just stopped working all the timers are switched off and the grill still works but the oven only heats up to about 80c the fan still works. any help would be greatly...
    ck wiring ( tec sheet inside the panel - there on most bosch a one time thermo / or it may be a resetable one .but you will have to reset it by pushing the red button . this may correct problem . if it does it again look for a over heating porblem like the ( fan foing too slow. ) or temps prob problems. .. mm / hope this helps / feed back pls /
    Dec 20, 2009 | Bosch HBN 3550 Electric Single Oven
    My HBL452 double oven is slow to heat both upper
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    heatman101
    Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
    Fan oven not heating, bosch hbn 202t
    May 04, 2007 | Bosch HBL 5032 Electric Single Oven
    Ovens Logo
    138 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
